Overloaded!
I threw some mud at the Horch today using the same mixture as the base, and after a dark brown wash and various watered down warm greys I fixed the wall in place too so I could blend it in with the ground a bit. It needs more detail painting but I won't be going too mad as I like the general look as it is. I've added some lichen & moss effects but the camera isn't being kind. Maybe I need to ramp those up.
I started adding some ground cover as well. After my last base where I did the static grass before the ground cover I learned that's definitely not the best way to do it!
I also started on this creation. I won't insult Mother Nature by calling it a tree but some twisted florist wire and home brewed goop saw me with this, which actually doesn't look too horrific once planted.
Some kind of foliage to follow of course.
Looking a balanced scene Andy, esp with the tree :thumb2:.
Don't think there is anything amiss with the shape of the tree either , looking fwd to the foliage part .Any ideas yet ?
Thanks John.
I do have some seafoam that I got for my next project (this is a bit of a warm up / test bed for that) but haven't played with it yet. I was going to glue bits of that to the "branches" and add some paint, but since I'm aiming for quite a lush look elsewhere I don't think it'll be enough.
I might end up with some woodland scenics foliage over the seafoam but will try a few ideas out.
Great idea Andy. Light applications of the foliage with either hair spray or something like 3 M spray adhesive will give a superb effect .
Well, I can't say that adding seafoam is fun :smiling2:
Once I'd done a few "twigs" I got a system going though, so after nearly a full day bar a few sanity breaks I had it done.
To cover the superglue and differences between the branches it got a coat of Mr Surfacer, a black & brown mix
I got out my can of spray glue but a few years in the shed had rusted the top meaning it wouldn't spray, so out came the hairspray. A few a few layers of that, flock, hairspray, flock, etc and we got this.
Not as good as I was hoping for and definitely not worth the effort, but adequate for a first attempt at this technique. From a reasonable viewing distance (like mars) it gives the impression of a tree like object though, so it's staying :smiling4:
I might add some highlights and shading but I'll see how it looks once it's dried overnight
Well, sitting here on planet Earth, it doesn't look half bad to moi!! You should be pleased with how it's turned out.
Looks good to me Andy :)
As you say,maybe a bit of tweaking colour wise, with some hi/low lights of various greens and I reckon you've cracked it. ;)
Most excellent tree work Andy!!! It definitely looks like what it's supposed to look like. Take a bow, Sir!!!
Allen
Thanks everyone. The flock / foam looks unrealistic close up but since it's all I had I can't complain :smiling3:
I'll try and jazz it up with some paint tomorrow. And continue the search for the bit of fence I broke off....
Many thanks for the honour John. I must admit I'm liking it more the morning after.
Trying to shape a "flat" side on it over the track where tall vehicles would naturally keep it trimmed back was tricky but it's somewhat there.
I plucked out some of the foam today and gave it a bit of variation with Ammo shaders. It's now glued in place but needs blending in with the base once it's hardened up.
I also finished the ground cover and added a bit of static grass. Will look at it with fresh eyes tomorrow and see if it needs any more.
I'm probably going to call time on this one. I keep thinking it needs something else, a bit of roadside debris or a signpost for example to add a bit more interest, but with the attention span of a goldfish I've already started another project so it's doubtful I'll get back to it.
I tried out a few new products and techniques though, had fun, and I'm pleased with the outcome. What more could I ask for! :smiling3:
I'll try and get some better pics over the weekend for a completed thread.
Thanks for looking :thumb2:
Andy, mate it's damned good , looks exactly like a Hawthorn you see on the road side .
Thanks Andy and Steve.
Cheers John. I'd love to say that's exactly what I was aiming for but it just wouldn't be true :smiling5:
Much happier with it after the extra work though and I'm glad it's recognisable, thanks.
