Papa695s Gillow’s Spitfire MK1
27B12468-161E-44CE-9AC4-ADAE219CCFD6.jpg 0B33AE9F-9CBF-42C9-982C-22F65E9462A9.jpg 07C999D2-4587-45BD-981E-7329B982E25E.jpg 0A4FD7AF-4FD5-48C7-AA4D-820BFF0EA6C1.jpg 452C726A-BF73-4880-8400-51CD73CE573E.jpg Finally got the wings built and the correct dihedral set. This is now ready for sanding, then it’s time to put the tissue on.
Earlier the iconic wing shape was apparent but now it's all together it is a real Spitfire.. Like John I look forward to seeing the tissue go on.
Sorry I’ve not been working on this for a while, but I’m back now. Time for covering with tissue.
C299F474-363C-44FC-B696-6B62A523EC07.jpg 8EF53C9B-8FAF-4FA4-A901-B7062C4298D6.jpg
The tissue looks to have gone on fine. Do you now have to tighten it up with dope??
I’m letting the glue dry for 24 hours, then I’m going to spray it with water only. That will make the tissue shrink. After that is dry, I’ll coat it all with some clear varnish to make it water proof so I can paint it.
Interesting technique with that paper... I used to make RC balsa models in the past, and we used a covering film you had to put on with a flatiron, the heat made it sticky and shrink... Looking forward to see the next steps, cheers
Great progress Ian. As a kid, I built a glider which was tissue covered. I still remember being quite amazed at how the tissue shrank after applying a bit of water. I'm wondering now, as it shrinks so much, could warping be an issue - unfortunately, I can't remember.
Thanks Colin, and yes warping is an issue, I’ll post some pictures of how I go about that shortly.
How I stop parts warping after wetting the tissue, I make a little jig using leftover balsa wood used for the struts. Covered in cello tape to stop the wet tissue sticking to them I then wet the tissue with a fin misting water bottle, then place them onto the jig, then using pins at the sides not through the parts hold them down until they dry.
F2B5677C-7CD1-4155-9A40-3EC0EFB0C91C.jpg 0A802025-F051-40C7-8835-CA41D6813CAB.jpg 9990E259-DD43-4ACA-8149-F1E7C1BF9D33.jpg 3FBB4894-4214-48A8-9D55-0536EA5C686E.jpg F117AFE4-C502-4290-8B82-A0D9E3374198.jpg
This is building up very nice Ian.
Good one with the water shrink. I used to use cellulose dope. That shrank the tissue and made it hard and paintable.
Water smells less though. lol
Hi Ian,
Just had a catch up, started to look like a Spitfire as soon as those wings turned up. Thanks for running through your anti warp regime, very interesting stuff ,watching these wooden models come to life. Fine job sir.
I’ve moved on a little with this one.
3EE904E9-FC43-4B94-B9B8-5FAAEBD02575.jpg D701607A-48CA-4C95-9A41-CC3BC2370086.jpg 5ADECE36-3AF5-4242-874A-B230CF6378D6.jpg C8CAC348-6E4C-40B4-89DC-F2F5D4E7CD7C.jpg
