Paul T's Spitfire mk Vc...... Airfix 1/72
PaulTRose
Tattoine
Paul
Tattooine
Going to park this here til i can make a start on it
I have a mk 1 in the stash but i fancied something different
This comes with 2 schemes.... 1 is a RAF green/grey but i fancy the Aussie silver one
Nice one Paul 👍
I’ve built a couple of these, it’s a cracking little kit I don’t think you will be disappointed.
Geoff.
Its a great little kit paul , I would go for the aussie one too , cheers tony
A silver Spitfire. Do it. I was nearly going for the red G-FIRE, but went a bit more traditional in the end.
Progress report
Dont know what i did wrong but i had problems getting the fuselage halves to mate up properly
The cockpit is a 'tub' that just seemed to be too big in height and width......... So it went on an extreme weight loss programme lol....... Extra coarse sanding sticks thinned it down so it went together
I'm glad you got it to fit. A little bit of plastic surgery does wonders some times...
Aah the extra course sanding stick, the modelling equivalent to a “Brummegam Screwdriver “ (hammer) 😂
It’s coming along very nicely Paul 👍
Geoff.
Good fix Paul. I had that same issue with my 1/72 Mk1 Spitfire years ago. Some do, some don't encounter it.
What colour should the exhaust stacks be
Pretty much depends on what finish you are going for ie weathered and used or fresh out of the factory. I have seen shiny silver exhaust pipes on some Spitfires but generally I go with a combination of brass/black or brick red/black combination. Its coming along nicely Paul.
