Pete's Eduard FW190A-8
stillp
Just be careful of the engine mounting and covers. If you don't get it right then you'll have no end of problems. But....
Defo following this build :)
Thanks Steve. A bit of a slow start, other things have been occupying me!
I will be watching. Eduard are good kits and I should think that this can provide a satisfying result.
Glad you're watching Barry, you can tell me if when I go wrong.
Haven't done much except for sorting out the parts that need to be in RLM66. My Vallejo RLM66 was standing for a long time, and is taking a lot of shaking to get it to mix. :disappointed2:
Pete.
Right although a wingy thing I shall follow, I need to learn about such things !
John.
You won't learn much here John!
I did get some paint on some of the parts, and even get some PE glued on today though. A dry fit of the fuselage halves + cockpit tub + engine:
View attachment 320476 That looks as if it'll be OK. Then to the start on the PE. I was talking to someone recently who recommended Gorilla Glue Clear for PE, an I saw some for sale on Friday so thought I'd give it a try. It has a good initial 'tack', but doesn't really grip the parts together, if that makes sense? That is, the glue grabs the PE, but then lets it move around to an alarming extent. I think I'll go back to CA or Gator's Grip. Here's the result of the first few parts:
Not looking too bad. I'll see how they look tomorrow.
More PE today.
These handles on the IP are stupidly small!
View attachment 320589Broken one off already, but luckily Eduard include some spares.
Glad I had the foresight to leave the rudder pedals attached to the fret while I bent up the heelrest and threaded the foot strap through the buckle:
All in place now:
They've had a touch of RLM66 on the pedals and leather brown on the straps. Should be able to get the fuselage together tomorrow.
Thanks for watching.
Fiddly little blighters aren't they.But they make the cockpit 'pop'. Looking good Pete
That cockpit look very nice indeed, well worth the headache from the tiny etch....possibly:thinking:
Yes, I agree on both points Alan, one of them has already escaped!
A little more done today, the fuselage is glued at the rear, the engine is just held in by the rubber band here to act as a spacer:
I'll need to spring the fuse halves apart a little to get two more parts in between them, so I'm leaving it to set overnight. One of those two parts is the upper IP, shown on the white tak above. What are the chances of that gunsight staying on...?
I've also started on the wing by gluing in a rib that forms the back of the u/c bay. I might regret that later as it fixes the dihedral. The wing moulding wanted to take a different angle to that rib, so I've had to glue it progressively. Fingers crossed!
Thanks for the encouragement folks!
It looks like you don't have to build the whole engine like you do on the 1/48 kits. If that is the case then please disregard my point about ensuring the engine build and mounting is done really well. I got it wrong on the 1/48 kit and boy did i pay for it later on lol
Looking good though Pete
