Plastic 5 inch Turret gear ring an motor gearbox
boatman
NORFOLK UK
as the tile says can anyone help me to find one so i can get my main 6inch gun turret to turn
chris
Chris are these any good link
HI Scottie many thanks for looking for me much appreciated
but im looking for somethng like the pic below of a gear ring an a motor gearbox to fit the gear pic below sorry pic wont show but its like a turret ring with the gear teeth on the out side an i need a small gear to fit the main gears if you see what i mean Scottie but cheers for lookin but i suppose i could have the movein gear fitted to the inside like the gears you have shown cheers
chris
I’ve had a look around, but can’t find anything. However, I don’t know what the proper name for those sort of gears. Strikes me that to look for what you need, you need to know what it is called Chris. Might be worth dropping Dave Ward a PM. He is a trained engineer and might know exactly what you are after.
I’ve had a look around, but can’t find anything. However, I don’t know what the proper name for those sort of gears. Strikes me that to look for what you need, you need to know what it is called Chris. Might be worth dropping Dave award a PM. He is a trained engineer and might know exactly what you are after.
CHEERS Tim i'll ask him
chris b
OK, just go to www.https://www.hpcgears.com/ and browse about. Or you could email them and ask if they have what you want - if you send them a few pics of your ships they might even offer you a sample...
Another thought - do you actually need gears? I was thinking if the motor had a rubber tyre (model car tyre?) on it's shaft, running against a smooth plastic ring inside the turret, would that work?
How many degrees does the turret need to turn thru ?
If less than 180 you could just use a servo motor to rotate it, like the servos used to raise undercarriage in r/c planes
cheers gary very good idea but im gonna have a look at an idea ive just thought up cheers for your help
chrisb
Chris
The other alternative is to use a cheap stepper motor to drive the rotation. I used one on my owl puppet to allow his head to turn.
Looks a great site Pete, must be something there for Chris .
