Portuguese Texan
The Migrant
This is an older build of the Occidental 1/48 T-6G Texan. From what I've read it's based on the Monogram T-6 but has engraved panel lines. It's quite a nice kit; detail's a bit soft in places but there's a lot in the cockpit, the clear parts aren't bad and the overall fit is good. I added Eduard PE flaps, brake lines from solder and added the underwing stores. Markings are home-made and depict a Portuguese T-6 used for anti-insurgency in Mozambique in the 60s.
Another stunner Mike, great attention to detail and the painting is first rate, great build from me mate, lovely aircraft.
Si:)
Outstanding build Mike, plans arnt my thing but thats a stunner. big 5* from me.
Beautiful build mike ,flawless paint job , and i'm loving the scheme too. Top work , cheers tony
Lovely work Mike. The Harvard is a regular vintage aircraft here in NZ, so seeing this warlike Texan with guns and rockets pods is a nice change.
Good to see you posting again. A great paint job
WOW were was this before, any build pics!
Great photography as well!
Gregg
Very nice, I do some paint and fabric work on T-6's at my local airport and there is also one of these ex-portugese T-6's although way more weathered and not as nice an colorfull as yours.
I have the Italeri 1/48 T-6 in the stach for next year, that is also a nice kit.
Theuns
Mike, a marvelously done plane! How did you get such a nice metal finish and markings?
Selrach
Thanks a lot guys, for taking the time to look and comment.
\ said:
VI have the Italeri 1/48 T-6 in the stach for next year, that is also a nice kit.Theuns
This is actually the Italeri boxing of the Occidental kit Theuns, perhaps I should have specified that in the OP. It's the same plastic, but the Italeri kit has a much nicer decal sheet.
Mike, a marvelously done plane! How did you get such a nice metal finish and markings?Selrach
Thanks Selrach, the model was airbrushed with Alclad II Aluminum and then flat coated.
