Queen Boudicca of the Iceni
Hi all
Did a bit more work on the horse, Colin perhaps you can ask your partner if the neck is better, ive also added some detail to the hair on the fetlocks and hooves
You can also see ive added the yoke blanket with the indents of where the yoke will sit
more to come
Paul
Much better she says ... :) :)
Great work as per usual Paul ... I'm still impatiently waiting for the end result though.
Oh and Mississippi can apparently come and live with us :) :) :)
Colin you and me both on the end result, i sometimes get a bit impatient when im doing a lot of sculpting as i want to get onto the painting part :(
Mississippi unfortunately belongs to our local farmer who bought it for his daughter, but i think we look after her more than they do
Paul
Bit more done to the horse, this time the mane and tail.
Im always dissapointed with the manes and tails that come with kits, on the whole they are very static with little or no movement and even though the horses are stationary there would still be movement in them, mississippis tail is never still swatting flies so with that in mind heres the mane from the kit
using my pyrogravure ive added extra length on using bits of spru
and carried this on for the whole length
I also added some bits onto the other side
Then started to add the hair texture
This needs to be done in several sittings
this will need sanding and then finer detail adding later on
Paul
What are you using to rescribe the detail Paul, power tool or heated tool?
Looks good anyway. :)
Thanks for the comments guys, Colin i use a pyrogravure, like a fine soldering iron, i made several different points for it ranging in thickness, A useful tool
Paul
Tony sorry just realised you are just accross the border from me in sunny Darlington
Paul
Brilliant work Paul, exceptional skills. I can't wait to see the finished thing should be really, really impressive (and quite large I think)
Keep up the great work
ATB
Paul
Tony just in also not so sunny Penrith :)
Paul cheers mucka, yep it will be quite big, give the wife time to get a shelf ready ;)
Paul
Ok on with the hairy bits o_O ill leave the mane as it is for now but i may add a bit more to it later, im not sure its messed up enough. so on to the tail, Missys tale never stops so ive given this a lot of movement
just heated it up a bit then bent it round
then added the detail in as per the mane
again still a bit more to do but its getting to where i want it
Paul
Hi Paul. That pyrogravure tool looks like just the thing I need for cleaning up the seams on my soft plastic figures. I've checked it out on the web and apparently it's no longer available. A few sites recommend using a normal soldering iron and grinding the tip to the shape you want. They also mention you need to adjust the temperature and some have made gadgets to do that. As I know even less about electrics than I do about the backside of the moon, can I pick your brains and ask if you can let me know the technical specification of your pyrogravure please?
Gern
Ah not too far away then, just across the Pennines. Nice to have another Northern boy on here.
And great work on the mane and tail mate.
Tony.
Dave my pyrogravure is actually a soldering iron, I bought several different heads and shaped them as I wanted, I havnt needed to alter the temp but I have seen irons that have an adjustment on them, they stopped selling the real deal several years ago, something to do with elf and safety and plastic fumes, obviously in our nanny state you have to be told to wear a mask :eek:
Tony yeah not to far away, did you go to the ipms show in Darlington ?
Cheers Polux your comments are much appreciated
Paul
Hi all
I thought id add a few accoutrements to go on the chariot, so the first thing is a recurve bow, now on the whole the bow was mainly used as a hunting weapon, but as many have been found with chariots at burial sites, and I cant imagine anyone having a weapon like this and not using it in battle ive decided to add one.
I then added a carrier for it
So that's the twanger, ill add a sheaf of arrows later, and ive also made a chucker
Not overly happy with the pointy end so ill make another one later, There will be about 3 spears in a holder on the side of the chariot as well as the bow and some shields
all for now
Paul
Thanks Paul. I'll have a look around for a suitable soldering iron.
I take it from all the weaponry that you've decided not to show her on her wedding day!
Gern
