Revell 1:32 D.H. Sea Venom FAW 22
Thanks chaps for stopping by.
Silvering, can be a bit annoying especially when you’ve taken all the normal precautions. I’ve even tried to remedy the silvering which had some success.
However, some areas remain. So, time to attempt to over spray the affected areas. This is why I don’t bin used masking tape.
The low tack properties should, and I do mean should, be ok over the decals. Well, let’s see. I’m going in.
The Venom is basically finished, so how a bit of HMS Albion, from 1960, to sit on.
This is the result of tonight’s work.
That mottled look isn’t so obvious in real life, I’ll see what it looks like in daylight.
All done. Pictures are in the 'Completed Aircraft' section. Thanks to all who took time to comment along the way.
