Been fiddling around with this for a while now but not posted anything from it. This is straight out of the box, even going for the box art decal option with the groovy yellow wing tips and stabilisers.
Some good detail in the office - not sure you'd get much better without PE. Avoided the decals for the control panel & other kit, just a bit of drybrushing with a spot of colour here and there for interest.
Toothpick for scale... using 'macro' mode on my phone makes the model seem huge!
This was an absolute cow to get into the fuselage. But I got there eventually...
OK say goodbye to all the interior detail...
Sob. You can't see anything. But hey, this is a big ole beast. Have primed the wingtips with white so they'll take the yellow better... hope this works out.
See? Hardly anything visible! And once the canopy's on... Sigh. I'll know it's there.
Some lovely detail in the wheel well, and some of this will be visible. From underneath anyway.
So this is where I'm up to now - have assembled the engine nacelles. Even cut out a panel on the starboard inside engine to reveal the powerplant (not a lot of detail). If I get the new Airfix Bomber Resupply set as I'm considering, will have a gantry up against it and someone tinkering.
Like I say, not much detail.
OK so that's where I'm up to now. May make some progress over the Bank Hols weekend, hope to at least get the nacelles all fitted and hopefully the undercarriage in position. The undercarriage, it must be said, looks mighty fiddly. When the instructions say "use tweezers to get this tiny bit into position once everything else is all cemented up", I read, "You've no chance of getting this right..."!!!
This is the most complex model I've attempted to date, but on the whole it's gone together OK. Taken some finessing at times and the ole "brute force & ignorance" approach at others (buttoning up the fuselage resulted in my wee boy learning some new words...) but it's a good-quality model and I'm really enjoying it.
Will update when there's some progress.
