Hi, I hope this will become a quick build as the kit looks good and parts aren't that many.
First thing was I had forgotten I had this kit and only just found it under my pile of kits that were salvaged from a flood back in 2006. The salvage team did a good job and most of the parts were intact as somost were still bagedand wasn't touched by mud. The box however bought it, the instruction sheet stained and decalsto be seen if they still worked.
I'll start with the customary sprue shot...
The kit comes with PE for the nose antenna and other external probes. Looking at the tightness of the cockpit to the fuselage I will be pressed in finding space for weight storage. I will have to improvise.
Overall surface is finely engraved. I will know when the fuselage halves are dry fitted to see if the fit is good.
Looking forward to building this Alien of a head looking aircraft.
