Richard's Dragon 1/72 He 219 A-0 UHU Night Fighter
Hiya Richard,
That cockpit looks very nice but I’m Seriously blown away with those homemade seatbelts:thumb2::smiling4:
Thanks fellas, John, Bob, Si and Joe...
I wear a pair of Caterpillars John :smiling6:
Bob for you I will try a SBS
Si, I have some laser cut belts and since they need to be put together why not cut some paper and try it out. All you need it is tweezers, steel ruler, sharp tipped blade and a good pair of eyes for scale. And of course you need to put aside some accuracies. :smiling2:
I hope the landing gear is strong too Joe :smiling6:
Hi guys, did a bit today gluing the fuselage, underbelly pack and gun ports, tailplane and the wedge or spacer at the back of the cockpit.
The wedge or spacer was kind of undersized and created a noticeable step for the canopy and fuselage top. For the canopy to fit snugly I had to sand down the front hood slant.
The extra plastic strip shims helped elevate the spacer to reduce the step and gap.
Once the glue has hardened I'll slice off the extra plastic, apply a bit of filler and sand smooth.
Some shims were used too for the other joints in the belly and tail assembly. I have yet to attach the bullet proof windshield above the dash board to see if it fits with the canopy on. The distortion from the canopy makes the interior look a little better. :smiling6:
Hi Richard
Cockpit looks great. Very nicely done seatbelts. There seem to be a few fit problems but nothing you can't correct.
Thanks Jim, homemade always has that different satisfaction. Was expecting minor fit problems for one of Dragons early kits but coming along fine. Have puttied now waiting to put on the second layer.
Ok for Bob...let me introduce you to my new scriber aptly named...
It cuts very fine which means a few repeat runs to get the right depth and thickness of the groove. Besides this I also use an etch saw. For this particular scribing process of lines not joining where they're supposed to, its good to decide which half of the lines need filling and rescribing.
I like to add liberal layers of putty and let them cure for a day or two. This lessens the refilling of shrunk putty.
Everything that looks like a seam line was puttied.
Next to sand when fully cured.
Nice work on sorting those panel lines.
I like the look of the UHU. I have been tempted a few times...
Looking really nice Richard. That's some serious lead work going on there. Last time I dealt with a tail sitter (Gannet) I ran out of space for the lead in all the conventional spaces so ended up using the forward edge of the wings. I'm still waiting for the nose wheel to collapse !
Thank you gentlemen, scribing needs a bit of planning and so is the storage of lead weights. :smiling2:
I have dry sanded the panels and joints and refilled parts that needed extra putty and re-sanded. Once happy I'll go over with wet sanding in finer grit.
You can see the panels that were sealed over and just make out the ones filled with the sanded dust, a brush will help dig them out. I will now use them as guides to scribe the opposite side.
Below you will notice after dry fitting that it won't be a tail sitter...mission accomplished.
So now it's up to the undercarriage strength...fingers crossed.
Just found this, neat looking office and seatbelts Richard.
Good job with the weights too :thumb2: .
Hi Richard
Filling looks good. I have always tended to fill and smooth before the putty dried and as you say that risks the putty drying slightly sunken. That results in another filling. Your idea of filling proud sound like a good idea :thumb2:
If you had all that lead in it round here some one would nick it Richard !
Are you fitting a steel undercarriage !:flushed::smiling3:
Do feel sorry for the poor guy in the back sitting that way round, must have been an uncanny feeling.
Hi Fernando, Jim and John, thanks for the comments.
It's ok if you've just joined in. Good to have you along.
Hi Richard
I used to do the same of smoothening the putty when filling but saw some other guys just plonking heavy and found that it was practical. You still have to apply in layers but it's quicker.
It's lead free here so no worries. They'll be plastic all the way. The back guy gets a round stool seat, I guess he can turn it around if he felt uneasy.
Scribing this time was done with the etch saw on the main panels....since it was straight across from the existing line.
The other panels were done with MAD.
Wing leading edges will need a liitle putty as the glue didn't quite ooze out leaving a seam line.
This is coming along quite fast. Soon I'll be fitting the wings to the fuselage and dipping the canopy into Future.
Hi Richard
Looks as if the scribing has worked well. Is that that Dymo tape, used to give a firm scribing line?
Hi Jim, yes it is. Surprising the stationery shops still stock these archaic labelling system. I have had my roll for years now. Perhaps the older shops still have left over stock. I find removing the backing film to expose the adhesive very annoying but works just fine because of its rigidity...doesn't bend at the edge and size...not too broad.
Hi,
I washed the canopy in detergent, dried it off and dipped it in Future and let the excess get soaked up on the tissue. All fine scratches disappeared and it was gleaming.
Put on the front wheel undercarriage and confirmed it won't sit on its butt no mater how much I pressed the tail down. She weighs a ton though. :smiling6:
Now its cleaning up the wheels and putting the propellers together...the blades are all separate.
