Rick’s 1/72 Airfix Phantom FGR2 - in the hangar.
rickoshea52
Rick
This is my next build but definitely not an out of the box construction.
The kit. This has the parts for an FGR2.
The extra sprue for this version.
The aftermarket. Etched brass and paint mask from Eduard but some of the ejection seat stuff might not get used.
The resin is a mix of Aires and Blackdog. The observant will see the engine is not a RR Spey, but have a plan for this.
The decals; still not sure which to go for.
The setting - I’m going to re-use this hangar diorama base. The Lightning is a little smaller so some sizing up was required to see if the Phantom will fit. Some adjustments to the scene will be needed but mostly just moving figures and GSE.
Because this Phantom will be on jacks with some panels removed I need to do some marking out for cutting and drilling. The stencil application guide helpfully indicates the jacking points on the aircraft underside (don’t get them confused with the wheel change jacking point markings on the LG door).
I have some other stuff to wrap up before I get stuck into this no you’ll all have to remain patient for updates.
The reason is a mix of Aires and Blackdog. The observant will see the engine is not a RR Spey, but have a plan for this.
:thumb2:Something to look forward to Rick!
Fantastic stuff rick , looks a lovely kit to base the dio on , cheers tony
First aircraft I saw take off. I was in the tower at some USAF airbase in Suffolk. RAF Bentwaters. (If I recall correctly)
"Two burning, two turning ready to roll" was the take off request from the lead aircraft!!
Magnificent. You can't dislike a 'toom'!!!
WHAT oh how long will we have to wait ? an love the lighting under maintance brilliant is this dio in this forum ? as i would love to see it
chrisb
NOW THAT Rick is a sight id seen loads of times when i was young an with my dad crane drive at raf cotishall lifting the engines out af the lighnigs back in the late 6o's so what brilliant dio this is an you put this on 3 yrs before i joined the forum an Miko would proberly like to see this wow
chrisb
Thanks Chris.
If this type of thing lights your lemon then check this one out too.
https://www.scale-models.co.uk/thre...rier-gr3-4-sqn-royal-air-force-germany.37988/
Watching with interest being a Phantom fan.Ive got the Airfix FGR2 in stash plus 10 Fujimi ones and Revell F4 J.
Looking forward to this
Wow, not seen this - I thumbsed up and then noticed the date. Very ambitious work but it’s going to look the business when complete I’m sure. I think I have the FG1/FGR 2 1/72 - but I think that will be as is - I was actually tempted to do it for the GB before I switched.
Getting the resin detail parts to fit are, unsurprisingly, a challenge. They’re not designed for the Airfix RAF Phantoms so a fair fit of test fitting, trimming and filing is required.
The forward avionic bays have a massive gap which will need a bit of filling with a plasticard shim. There’s also a small gap between the fuselage halves.
The spine trunking casting needed a bit of sanding but it just about fits.
And initial coat of paint applied.
The engine and compartment are the other tricky bits. The engine isn’t a RR Spey and the afterburner nozzles look awful so I’ve used a reskit for a Spey engine. The old nozzle was hacked off but the new one doesn’t quite match the internal diameter of the jet pipe. Hmmm?
I also realised I don’t have any epoxy adhesive so off to the shops I go.
The spine trunking looks great Rick. Hope you can get a resolution for the exhaust to engine fit.
