Russian T26 Tank - Revell - 1:35 - (WOT's version)
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
My next victim.....I got this kit for free. Its a Revell 1:35 World of Tanks (WOTs) T26.
I had a problem with a previously made Revell Half Track, and emailed them to complain, so Revell sent this to me for free as compensation.
I know WOTs is an online tank game, and this has some ink with that, not sure what, as I know that the T26 was a significant tank for the Russians, so it is a "real" tank IYSWIM....
It is not without its own problems, (see photos below).
Box and sprue...
Not many parts (172) and looks like a relatively easy build, we'll see. A few very small bits, especially around the wheels/suspension and the top of the turret, wire frame, etc.
The decals sheet appears to have all the decals for all the tanks in this (WOTs) series, which are fairly generic, so I'll just stick to the few Russian stars and maybe one or two of the others, so looks like they will not be ascribed to a particular group/scenario, etc?
Have already made a start a couple of days ago, so main chassis /body already assembled along with the turret. A few small gaps, but nothing major TBH.
I have noted that two (one on each side) of the main plastic "prongs" are missing, (that hold the lower wheels/suspension assemblies....snapped off! I did check the bag/box but they are not in there, so wondering if this kit was a return or a faulty one? So will need to sort the missing pieces out with some new prongs, etc.
This kit is also my first with some individual tracks, so we'll see how I get on with those. Thankfully its only a few individual track bits, around the drive wheels, etc, the main track lengths are already made.
Great start, I resold a WOT kit once when I discovered it didn't have any 'normal' decals lol. Looking forward to see what you'll make of it - have fun :coffee:
Nice start Peter. That was good of Revell to acknowledge you and send you this kit. There are a few Soviet-style decals there, should be able to cobble something together. You must have a box of left over decals?
Yes, was good of Revell.....I do have spare decals, but no Russian ones, think this is the first Russian kit, of any sort, that I've done....
If you have a steady hand you can brush-paint things like text and numbers, the Soviets didn't care too much about perfection.
  • this-photo-shows-a-t-3485-tank-from-the-11th-armored-corps-in-central-berlin-during-the-final...webp
Not had chance to do much last couple of days, (playing with my new PlayStation PS5 Pro, Lol!) but managed a bit last night.
Almost finished the wheel/suspension assemblies... bit fiddly, but ok.
Also done the drive wheels....and exhaust....
Managed to bodge the missing rods that had snapped off, got some sprue that was roughly the correct diameter, sanded it down a bit, (will need more fine sanding) and flattened the ends and glued them on, well see if they hold ok?
Completed the wheel/suspension assemblies with the second side plates glued on, they have some small gaps so will need a bit of filling.
Did a bit of filling to some of the gaps. Once dry will sand and then give it all a coat of primer.
Primed up most parts.
Starting to come together.
Decided to add a couple of Russian tank riders, as I have a MiniArt figure kit.
Made up the figures but one had a weird looking arm!
He's supposed to look like his left arm is leaning on something, but to me it just looked too long and at a weird angle, so I had a rummage through my spare figures box and found a suitable left arm and have now attached that, gives a better pose IMHO.
Should have added/clarified that the arm on the box art (in the picture above)actually looks ok, but the arm that is actually supplied in the box on the sprue is much straighter, so no matter how you attach it, it just makes the figures look like he's reaching! Hence why I changed it....
I’d get more modelling done if it wasn’t for that too :) even less in July when I get pre-ordered AC Black Flag🏴‍☠️
First top coat is now on the main body. chassis and turret, and the tank rider figures have now been primed and started painting the uniforms.
Tracks painted up (primed and then first coat).... they have some ready made pieces and some singles that you have to assemble, eg: curves at edges around drive wheels, etc. Bit fiddly....
Wheels and suspension installed, my "Acme! replacement prongs, to replace the originals that were snapped off, seem to be holding up ok? Started assembling the tracks, not the best fit TBH.....one side done, but a couple of bits look too "angular" IYSWIM.
Depends what angle you look at them, from underneath they look a bit cack, but from above/the top they are not too bad...
First side tracks done.... there is a little bit of track slack, but not much.....so onto the other side late....
Bit more progress.... Tank riders painted up a bit more, not finished yet, but just some tidying up to do.
Main build now pretty much done, tracks are on, and gave them a rusty red colour, all the little bits now added to the chassis/body, eg: track covers, pioneer tools, rear exhaust painted, various brackets, towing hooks, whacked a few spare tank tracks to the front, access panel handles, still need to tidy everything up. But for what was effectively a free kit, its not scrubbing up too bad.
Side view of the tracks, etc, I will paint the rubbers on the wheels tyre black and go round and touch up any bits that need it.
Then we will be on to a varnish cat and applying the decals.
This one is now done I think.
Did not turn out too bad for a what was effectively a free kit to me.
Did some very light weathering, grime wash, panel lines, rust wash, etc.
More pics will be added to a completed thread.
T26 Russian tank 19may26 pics6  (1).webpT26 Russian tank 19may26 pics6  (2).webpT26 Russian tank 19may26 pics6  (3).webpT26 Russian tank 19may26 pics6  (4).webpT26 Russian tank 19may26 pics6  (5).webpT26 Russian tank 19may26 pics6  (6).webp
