Scotties Bedford RL
Whether to prime or not depends on the paint you use, I’d say. If you like spraying Tamiya or Mr. Hobby acrylics, or probably any lacquer-based paint, it’s probably unnecessary — though you may want to prime the metal bits anyway. For water-based acrylics, though, I definitely would put a primer on first.
I only use primer on resin when it's really glossy, but yours is very dull & has a strange finish so I would go ahead.
RLs were generally Deep Bronze Green until later (much later) in my experience mate - depends on when/where you are portraying your masterpiece (ie some UK Base Depot or a BAOR unit ... some lasted in the former until well into the 80's.
You really are making a superb job of this.
Your 'silkpursery' knows no bounds.
Paul sums it up nicely.
Personally I would prime. If for no other reason than it will highlight any areas which might need some remedial sanding or filling.
Cheers Jakko I normally use acrylic so I might give it a prime.
Cheers Paul, everything about this build is strange mate.
Steve, I will probably go for a deep bronze green now have to find the right colour. We still had an RL box body when I was in Germany in the early 80's.
Jim that's a good idea no doubt there will be lots of imperfections by the time I'm finished.
Primer on the resin & metal would be a good idea, it would, at least give a prepared, even surface to paint on.
I've never seen anyone post that they regretted priming a model. Plenty (including me) have regretted not priming.
I think the Bronze Green would be well suited to the old "Beddy"......Prime or perhaps a black base in case you would care to do a little modulating of the final color. ;)
Graeme, I agree i Think its the way forward.
Rick. Bronze green it is.
Another update you must be bored stupid by now. The load bed is now fitted and apart from a few blow holes its quite well detailed. As the build continues I have come to realise how much of the kit is missing, these I will come to later. The lockers have been added along with some etch padlocks from the spares box. Also fitted are the POL carrier and jerry can rack. The mud guards and brackets were soldered together for strength and then fitted. The tailgate damper was missing so I have made one from a few bits of plastic and wire to represent the spring. Next the convoy disc and number plate were added from the kit etch. Missing were the lamp holders for the said items so these were fashioned from evergreen rod. Also missing were the rear light brackets and lights. These were made from some brass sheet and the lights, referred to rubies because of their shape in the military were made from punched plastic and foil. The wiring/and bulb holders were added to the back from lead wire and tubing.
Enough dribble here are some pics.
Thanks for following along
Scottie
Much "silk pursery" in evidence here!.......not bored in the least Sir! ;)
Thank you Rick.
How on earth could we ever get bored of admiring work like that?
To Kind Andy.
More mastery every time I pop in for a look. Excellent Scottie.
Nick
Cheers Nick.
Coming along very nicely mate!
Cheers Steve.
Thanks Neil.
Incredible work Scottie
Thank you kindly Mick.
Superb work Scottie. The model must be getting very fragile with all your detailing.
It is Jim. I have all the etch tie downs to add yet.
Looking fantastic Scottie. Looks like you cracked the glazing OK.
Tim, I hope so there was no good location on any of them and its the first time I have used a glazing film on curved surfaces.
Replacing the missing parts continues. The rear tow hook has been scratched believe it of not there are 15 parts in this if you include the punched detail.
cheers Scottie
