Scotties Humber Mk1
Hey Paul,
I guess I had one too many. What I meant was are you going to put Michael Caine in the TC hatch, Not Sean...…...Hic...…..
I'm surprised nobody caught that error……….
I did but was too busy shuffling my relatives around to reply.
Scottie(I have to one day make up my mind to either call you Paul or stick with your callsign :smiling2: )...your OOB interior is looking good, the tardiness is excusable. Blame it on the war and no time for clean up.
Hi Scottie
Now that interior is very nice indeed. A lot of work has gone into that and it shows.
Another beauty. PaulE
Richard, Call me anything mate I answer to most things. That's my excuse as well they are busy pushing on.
Hi Scottie
Jim, Thanks mate its amazing what a bit of muck will do.
Scottie
That really is rather good indeed. Very nicely done.
Just wish my skills were up to what you've achieved so far.
This really is going to look very special once finished.
ATB
Morn Paul,
Up to your usual handy work I see. Looking tops that Man!!! A quick question that you may be able to answer.
Did the real vehicle have the tunnel over the front axle? It seems it would be uncomfortable for the driver to drive it with his legs over the tunnel to reach the clutch/brake/gas pedals unless his seat was raised/reclined quite a bit. TIA Buddy!!!
Allen
Scottie,
Just caught up - brilliant. :thumb2: x 5.
Mike.
Mike, Praise indeed thanks mate.
Scottie
ATB
Andrew thanks mate, there is nothing wrong with your skills mate.
like that progress Paul
Thanks lee.
Nice interior Scottie :thumb2:
Steve cheers Fella.
Morn Paul,
Allen
Thanks Allen, as far as I can see the vehicle did indeed have the hump over the axle. I can only guess that the seat gave the drivers legs the support they needed but it still must have been uncomfortable and not easy to get in and out.
Not a lot done. I did remove the moulded louvres as they were far to thick and replace them. The etch towing eyes were added with some punched nuts. The exhaust was also drilled out. Finally the lashing eyes were replaced with 0.3 copper wire.
The front suspension was quite fiddley with very small glue points so I let each stage dry thoroughly before adding the next part but before they dried I checked the next part would fit. It builds up to show some nice detail. I will add some brake lines when I add the hubs.
cheers
Scottie
Scottie,
Some intricate work going on there, looking well good.
Mike.
Scottie,
Mike.
Thanks Mike give me a few years and I will be up there with you.
Great work - shame so much will be hidden by the wheels.
peter
Thanks Peter, That's why I never normally bother with underneath.
You are already there, do not go by my standards, there are much better modellers on here than me.
Mike
Not a lot done but it is quality work. Glad you changed the louvers. Wonderful work all round mate
Hi Scottie
Fiddly, careful, paintaking work but certainly effective and worth the effort.
Steve thanks fella this is a slow build but enjoyable glad you like the louvres.
Hi Scottie
Jim, It is not a bad kit but does have a few issues which may be down to me so tweaks are needed here and there.
