Scotties NAG
Great CITB. Will the lid be up?
Thanks Paul, yes the lid will be up and the side doors open as well as I intend to have the vehicle and crew working on and engine.
Sorry im late to the party. This looks an interesting kit to build. Scottie I love the attention to small detail within your build. Lovely modelling. 👍
Sorry for not posting for a while, but I haven't been idle. This kit really does need some serious thought. The chassis cross braces had been fitted as per the instructions, only to find that the load bed would not fit and if I got it to sit down it was at an angle. So I had to remove the braces and repair any damage caused. They were then fixed to the load bed first and after marking out on the chassis where they should fit they were secured to the chassis.
The wheel chocks were re done as I wasn't happy with the first ones.
Then the deck was sprayed with wood, after this had dried hairspray was applied and dark yellow applied. I wanted to keep the wear and tear focused around the jib so the wear is primarily shown where the crew would walk the jib around.
I have filled the location points in the cab for the rear view mirrors as the pictures I have show them on the doors.
Some light dust and dirt was applied to the chassis rails
cheers
Scottie
The wheels are on and a few more details added.
I still have to add the strap that stops the cans falling out.
cheers
Scottie
lovely weathering Scottie. Not sure if its my eyes but the tyre also look to be carrying some weight, very impressive.
The vehicle is nearly there now a few things left to do but these will wait until its positioned on the base that I am still pondering. All the lifting and recovery tools have been assembled and fitted with a few improvements here and there.
Next up work starts on the Jib.
Thanks for looking
Scottie
Looking fabulous...
Nick
Well Scottie that was a very enjoyable catch up with your build which I had completely missed. I did chuckle with your opening post when I read "The detail is not bad but it can be improved" I cannot remember anything that you've produced that hasn't been. This is developing into yet another master class.
Lovely work Scottie, looks all very high standard as usual, have fun, cheers
