- Joined
- Apr 27, 2018
- Messages
- 15,203
Ha ha thanks for that :smiling:How i generally do my rigging is by starting on one side and then seeing what else i got in the stash :tears-of-joy:
Its not that its overly difficult,just requires a bit of thought and patience which you have, for me to have any patience I'd have to become a doctor:smiling3:Ha ha thanks for that :smiling:
Scottie, it's the detailed grundgy weathering of the dashboard that the wingy guys often can't do. You've done it realistically. I like the brass work.Not a lot done engine is started and the instrument panel.
I am impressed with the Eduard plastic and the details everything goes together very nicely so far.
I still need to add the pin wash .
I tried to get a wood effect on the dash. I painted the dials brass then added the PE dial faces then sealed them with gloss varnish.
Any suggestions from the wingy guys I would love to hear them.
cheers
Scottie
I knew it - brilliant!Not a lot done engine is started and the instrument panel.
cheers
Scottie
Thanks Jim.Nice start Scottie. The dash is particularly effective.
Cheers Bob.Usual quality Paul and a very interesting build
Thanks Paul still a pin wash to do.Looks like wood & brass to me, nice.
Cheers Mick, It is so easy to miss builds on here with the amount of quality builds going on.How did I miss this. Definitely one to watch :smiling:
Thanks Mark hope my luck holds.So far so good.
Cheers Richard it's hard to know what is right when you don't normally build these.Scottie, it's the detailed grundgy weathering of the dashboard that the wingy guys often can't do. You've done it realistically. I like the brass work.
Wabble
Neil to kind Sir.I knew it - brilliant!
Thanks mate you are perfectly correct it is indeed an Albatros I will be seeking medical advice as soon as I can or changing my Sherry provider.Morn Bro,
The wing thingy is looking real good Paul!!! I love your work on the IP with the glass looking instruments. very realistic. Something puzzles me though Paul......
If you are building an Albatros D.III, why is your thread title for a Spad XIII???...............Been nipping the Sherry again Buddy???...
Allen
It's ok Bro! It just caught me out there. I looked at the instructions for your kit and saw at the very bottom there was colors for a Spad XIII, so it probably threw you off a little...It's all good, in fact, real good!!!Thanks mate you are perfectly correct it is indeed an Albatros I will be seeking medical advice as soon as I can or changing my Sherry provider.
Easy Killa!!!........ What's in a name Scottie?!!....
