This post is not about a part of the model itself but non the less important for that!
The ailerons need to be joined by a length of thin piano wire, at this scale “quick links” are a non-starter mainly because of their size but in any case there are no detachable linkages on the full size Se5a. Therefore the upper and lower wings will be permanently fixed together by the interplane struts and the aileron linkage; I don’t haven’t enough room to be able to keep the model permanently rigged so this could cause a problem for storing the wings when removed from the fuselage.
I’ve made 2 frames to support the inner sections of the wings; they are in 2 parts and held together with removable pins.
The wings will be stored “hung” from brackets by the top wing, the lower wing supported by the interplane struts and the frame, which grips the trailing and leading edges.
To assemble the model the wing locating pins are pushed a little way into the holes in the centre section and wing stubs, which then take over the support of the wings.
The pin is then removed and the frame disassembled, the aileron controls connected and the wings finally pushed home and the wing retaining grub screws tightened.
That’s the theory anyway!
