SimonT - 1/35 Miniart Dingo - Rons Recon GB
Morning Simon
only really added the springs on this one as all other detail is in the kit.
.... oh yeh!! Having just caught up it seems that you're back to your old tricks. Mk2 map case is much better. Making those sand has worked really well. Very clever method.
Loving the sand channels Mr T.....I’ll have to remember that when I do my LRDG Chevy :thumb2:
Beautiful work on the sand channels. A simple but clever idea. I tried to do one in 1:72 and failed miserably. Nearly there now
Great work. Surprised the material didn't try to crawl up the drill bit & make a mess of the hole. PaulE
Very impressive work Simon. Do you have any fingers left after cutting up the coke cans?
Simon,
I just caught up amazing work mate, where do you get the plans for the sand channels from if you don't mind me asking.
Marty
Jim - well, nearly OOB for me :smiling5:
Scottie - ta
Si - if you or anyone else wants a pdf of the template just PM me an email address and I can sort that
Neil - thanks
Graeme - thanks also
Steve - cheers. Could be done at 1/72, just needs a steady hand with the drill
Paul - held the metal against a piece of scrap wood. Just gave it a quick blast of Dremel on full speed - holes the result.
Without the centre being marked though the drill bit had a tendency to wander about - first two attempts had some very wonky lines of holes
Peter - thanks. Fingers all intact :smiling2: Cans cut very easily with a new scalpel blade
Marty - cheers. Made them myself as couldn't find any dimensions - studied various WW2 desert photos including one where a chap was very helpfully holding one up next to him, estimated some dimensions as a result, then drew up in CAD at work in my lunch break. They may not be 100% dimensionally accurate, however, looking at the photos showed that there were quite a variety of sizes and styles so I am happy that they are fair representation
Went through the instruction sheet again and found a few more small bits that I had overlooked previously
tie downs on the rear deck - etch fret provides some very small flat strips to represent these. I decided to drill holes and insert wire instead - that way I can lash some stowage to them
there was this little platform for the Bren to rest on made from two very small bit of etch and there was also a handle on the inside left if the Bren slot - just see it in the background
made up a pewter rifle sling and then cut two clips for the rifle from plastic card
this was then installed on the underside of the rear roof and the strap draped down on the equipment below
Bren barrel drilled out
I made a few Bren magazines using the kit part as a template only to find that they wouldn't fit in the rack as the etch slots are way too narrow - not a great problem though as rack is not really visible
This time, it really could be finished, apart from stowage.......
No it won't! LOL You will still find more to add. That's why we luv this kit bashing so much. However for me there does come a time when enough is enough and it's time for the wet stuff. Another great update Mr T. It's certainly looking the part
How right you are Steve
Something has been niggling at me - the things that look like bump stops on each side of the suspension uprights are not fastened to any moving parts so I have done some more digging
They are in fact brake pipe unions - there should be a small bore copper pipe from inside the chassis to the top of the fitting and then a large diameter flexible that runs down to the wheel hub/brake assembly
A few lengths of Plusmodel lead wire should sort this, then it might be finished.......:rolling:
Excellent details. My boss used to say the cause for my blown deadlines on restorations was "separation anxiety" where I had to do just one more thing, hating to leave my labor of love to some Philistine who wouldn't appreciate it and likely wrap it around a tree. PaulE
Jim - thanks, made me chuckle
Andy - good to see you, thanks
Paul - I know what you mean. I have the same problem at work when the numpties ruin my nice drawings
all four corners are now piped up so I am definitely calling the build done on this one now, honest
I have a day off Friday so you may even see paint soon.......
No paint yet but I have sorted the stowage and tied it all in place
dingo-077_2019-12-14.jpgdingo-078_2019-12-14.jpgdingo-079_2019-12-14.jpgdingo-080_2019-12-14.jpg
sand channels chained together
jerrycans are Miniart - have etch seams and cap levers
ammo box knocked up from plastic card
whole lot lashed down with none hairy thread 'rope'
All I have to do now is paint it........
