SimonT - 1/35 Miniart Dingo - Rons Recon GB
Morning Simon !
I see you woke up rather late according to the clock this time , either that or you were just starting !
Agree those springs look far better than the kit offerings.
I was just going to bed John :sleeping::sleeping: - don't forget site time is an hour out so it was only 2am or thereabouts
Thanks Scottie - always worth doing springs as they just can’t mould them
Nice work Simon, we could do with a step by step on making springs, yours are a big improvement on the kit parts.
Thanks Graeme
Not much to tell really - select some copper or brass wire of the right diameter to match the kit spring coils
find a drill bit or other metal rod/tube that is the correct diameter for the spring - when the wire is wrapped around it the resulting outer diameter should match that of the kit part
tightly wrap the wire around the drill bit to create a coil
slide coil off the drill bit
count the number of complete turns on the kit spring, match this number on the wire coil and cut the wire coil
space out the wire coils until the length matches the kit part - pushing a knife blade between coils usually works
you now have a replacement spring
that ok?
Sounds good to me Simon, will have to give it a try. :thumb2:
Graeme, here are a couple of in progress pics I took when making the springs for the other side
As well as winding and adding the springs to the other side I have been adding all kinds of small and tricky little bits and pieces
these tiny etch brackets each got a microscopic plastic bump stop (I think) added to the top, after numerous attempts punctuated by periods of scouring the floor for them
here they are installed on the sides of the suspension turrets - no location points provided and just a vague sketch in the instructions so had to guesstimate a position and then make them all match
jack added to front right wing
angled lifting eyes added to each wing
tiny hinges added to the hull side windows
rail added to rear deck for the open roof to sit on
exhaust pipe added
mudflats added to front wings
hinges added for side door and then side door hung in place
etch locks added to side bins
end of exhaust drilled out
headlights in place - unfortunately the right side had drooped unseen
tried to correct it but of course it sheared off so this will now need drilling and pinning
rear lights add to rear wings
side window hinges on other side
another shot of the roof rest
there are still lots of small fiddly bits to fit - the GB finishes next Sunday - this will not be finished on time
Hi Simon
You really do excel at this kind of work. The research you do and then having the skill to add the detail - impressive :thumb2:
Stunning work Mr T. I would have been surprised if you had made the deadline with all those builds on the go. All great things are worth waiting for.
Beautiful Simon...if yours is not going to finish, mine is still at the interior bottom half. Doesn't help if the cat has run off with the other GB's propeller.:disappointed2:
Thanks Scottie - most of the detail is down to the kit
Jim - only really added the springs on this one as all other detail is in the kit. It must be the fiddliest kit I have ever assembled due to the small nature of the parts
Steve - have been concentrating on this one and the Sturmtiger. Doesn't really matter if it is late though on here
Hi Richard - I may finish the assembly by the weekend but the painting will take it past the deadline. The cat's run off with my propeller is nearly as good as the dog ate my homework :smiling5:
Had an eye scan appointment this afternoon so took day off work which meant I could get a bit more completed
dashboard installed
British flimsy type petrol cans installed in the racks - added a few dents here and there
roof added in the open position
left side visor added with etched stay (you get open and closed position stays)
jack clamp added
right headlight drilled and pinned back in place
a couple of Petes friends from the pewter mine then took it for a test drive.......
dashboard installed
jack clamp added
Hi Simon cracking work on the Dingo, love all the up grade work you have done, that is not a road test that's a drive to freedoom
drive.....drivee.................driveeeeeeee..............................ddrriivvvveeeeeeeee........my little friends...........................farsstttteeeerrrrr...........
Pete.
They assured me it was just once around the block - does seem to be taking them a while..........
And you would believe what a 100% what a mechanic told you, I was one for 28 years in different positions and franchises so I think I can speak on their behalf it's gone..
I hope Pete's friends bring it back soon, so we can carry on enjoying this tale too!
Lovely work as usual Mr T!
Andy
