SimonT - 1/35 SU-122
Grant Line used to provide 1/87 nut/bolt assys. Still have some I think. Like Simon says, some plastic glues/cements will melt them. PaulE
Grant line is good but sometimes too large for my purposes.......makes small assemblies look clunky......working on a solution though. Rick H.
Cheers Scottie
Thanks Lee
Paul - I did get a large assorted box of Grandt Line nuts, bolts, hinges, lifting eyes, and the most useful wing nuts back around 1990. Pretty much only have the odd sized stuff left that will probably never be useful for anything! Tried to find their wing nuts recently but nothing doing - think they have gone bust from what I read
Rick - much more suited to 1/35
I think my body clock has a broken mainspring - been exhausted tired all weekend for no good reason and as a result spent most of it asleep. What a waste of a weekend.
Only really woke up around 6pm Sunday so not much done on the modelling
Did make a rather nice looking loaf though - finished baking just after midnight. All I can smell now is bread - yum
brass handrail added to rear of superstructure - kit one was broken any way
supports are from brass wire flattened with smooth nose pliers, wrapped around the rod and nipped up with the pliers
headlight added
horn hollowed out and added to the headlight bracket
the solid plastic kit tree saw holder replaced with a copper one - a 3mm strip was cut then folded up in an etch folder to make the U shape channel that it should be
No tree saw provided so may have a look at making one
filler caps added to the fuel tanks
track pin bashers added just in front of the final drive housing - loose track pins hit the steel block and get pushed back in to the track link
Presumably this only works for so long until the pins wear so loose they fall out before the track gets back around to the block
Simon. Details look very nice and don’t beat yourself up I’ve had lots of those weekends
For someone who has been asleep all weekend you still manage to pack a creative punch Mr T. Some lovely additions. It's coming along a treat
Thanks Lee - really annoying, wait all week for the weekend then sleep through it :rolling:
Cheers Steve - getting there gradually. There was a lot more left to do than I originally thought
Thanks Greg
knocked together a tree saw and started cutting in some teeny tiny teeth until I remembered that once in the rack only a few teeth in the centre are visible
looks rubbish at this size but the teeth are only about quarter of a millimetre in reality so it doesn't look quite so bad on the vehicle
this is it in the rack
broke the kit shovel so added an Armour Accessories one instead
managed to get the fuel tank straps a bit straighter
when I made the racks I was struggling to find pictures of these earlier style racks - I have tons of T34/85 pictures but the racks on them are a totally different design
Typically I found some pictures of early racks last night on an SU-100 so have modified the racks slightly to allow the straps to move sideways - not perfect but I am much happier with them now
Hi Simon
As always amazing scratch building. Really looking good. I reckon if you're sleeping through the weekend then you're working too hard during the week :tongue-out3:
Could be Jim - I need to sleep more at work :thumb2:
Only progress has been to add a radio aerial, a vision port on the rear of the superstructure and fill two small holes - not worth a photo
Steve - never even thought about that but yes, too small. Can’t easily use the printer as have had to dismantle my desktop setup to use works laptop
High Andy, good to see you. Thanks
Hi Simon.
I always liked the crude looks of the Russian Su family, so glad to see one being built. Impressive scratchwork going on here!
Hi Wouter - I do have a bit of a thing for T34 based vehicles. The stash is holding Miniart SU-122 and SU-85 and a Dragon SU-85m, Tamiya, Zvezda and Academy T34/85's, a T34/122 by Ryefield(?I think), Dragon T34/76, Zvezda and Italeri boxed SU-100, another Tamiya T34/76, SU-85, SU-122 all 35th, then Tamiya 1:25 SU-100, and 1:72 T34/85's by Dragon and Revell and 1:16 T34/85's by Trumpeter and Hobbyboss. Plenty to go at :rolling:
Back to this......
the last major part to add was this pair of rods. Have been unable to find a clear reference photo of them - vehicles are either taken from the other side or where they can be seen the pictures are too small and fuzzy
I have therefore made a guess that they are barrel cleaning rods......
....and replaced them with 1mm brass rod, textured with saw blade, Duro ends, pewter and plastic fixings
If anyone knows whether my assumption is correct or not please shout up as paint is not far away
Just four tie downs to add and the track links to assemble then it will be paint time
I think they're fishing poles or maybe one of the crew was a pole vaulter before the war. You could always stick with barrel cleaning rods though, after all it's your model ;)
As always your scratching skills are quite incredible.
Ah, collapsible vaulting pole. Now why didn’t I think of that :thinking:
morning all - having trouble with my wifi so posting is a bit of a problem
Have had to create my own hotspot on the phone and tether it to the laptop to be able to write this
called the build done on Saturday
the hull was cleaned down with lighter fluid and cotton buds - there was a lot of sanding dust and general dust as it had been sat for a long time with no progress
the hull was then given a coat of Halfords white primer but the wheels are still to do
they need the axle holes drilling out a bit more as the fit is over tight
the Masterclub tracks are giving me some grief
normally I like their tracks and have used quite a few in the past but the pins on these are really annoying to use
I have lost at least ten to the carpet and only managed to add four track links in a few hours
the pin ends are not well defined - usually there is a nicely moulded end dome or whatever but on these they are just a slightly tapered rod without a proper end
if you get them in the wrong way around, which is easily done, then they jam part way into the hole
they will take a while to complete at the current rate
Simon. Progress is looking good so far. I’ve been like you all weekend sitting in my recliner after my chores in the morning building models lol
Nice update Mr T. I'm finding that with these click into place tracks, primeing them followed by a base coat and two coats of varnish makes them a lot easier to use during test fitting.
