SimonT - 1/35 SU-122
Hi Simon
Well it's been a while but great to see this again.
A beautyiful piece of work. PaulE
Rick, Jim, Paul, Scottie - ta one and all. Has been around for some time now so should really try and finish it off
the rack are progressing - looks like a couple have snapped at the change in direction from curve to the flat part at the top so will need a little tidying up
Well done Simon..really enjoying the scratchery.. what did you use for the rivets?
Hi Joe - if you mean the ones on the rear etch grille they are lead foil punched with The Nutter punch set
Yes those were the ones.. I am working on an old Tiger I tank from Tamiya...(ughhh,,yes the old motorized version) and I’ve been adding some bling with photo etch and other scratch stuff.. still have to add some additional bolts in many places. I have been using plastruct octagon shaped rod and cutting them with The Chopper... very tedious but def gives it the better look.. going to try some foil to see which I like working with better.. thanks for the input
Have one of the old tigers lurking in the stash somewhere
I sometimes use that hex rod for the 0.5mm
For larger sizes I have a couple of hex punch and dies sets
Is your build on here Joe?
Not yet...have not been able to make a lot of progress so I didn’t want to post anything yet
Those cradles are the "DOGS" Mr. T. What's the smallest hex punch and die set and who makes them?.....very curious about the possibility of using them in 1/87 scale if possible. Rick H.
Hi Rick
the smallest hex punch I have is 0.5mm and that would be a US product by The Small Shop called The Nutter
It only works with their own Tri-Foil, a special soft lead foil sandwich. The foil is quite thin which makes it better suited to the smaller scales in general
0.5mm / 0.0196" equates to a bolt/rivet of 43.5mm / 1.72" in 1/87 which would be quite large
The Nutter set also comes with a round punch at 0.25mm / 0.0098" which equates to a bolt/rivet of 21.75mm / 0.85" in 1/87
When you get down to this size it doesn't really matter about it being round (you wouldn't be able to distinguish between round or hex) so you can use it to represent bolt heads or rivets
Conventional punch and die sets that can be used with any material you can get in them, but typically plastic card, don't go down this small
I have a UMM-USA hex - that only goes down to 0.8mm and the RP Toolz hex set which goes down to 0.7mm
UMM-USA round and RP Toolz round both go down to 0.5mm
I have not come across anything smaller than The Nutter 0.25mm round and doubt we ever will due to how fragile they would be
Thanks for the information Simon, I will look into it further as I am interested in producing rivets and bolt heads where needed in 1/87. I'm not a rivet counter but sometimes they are essential when scratch building or adding a modification to an existing model.
Cheers, Rick H.
I used to use cubes of 15thou plastic card when scratch building in 1/76.2 for model railways....but you have to cut your own plastic strip because nobody makes anything that fine. Anything smaller will probably dissolve away when you glue it on....
No problem Rick
Tim - I use CA so they don’t dissolve
Cheers Steve
Last night I added all the tank strap mounting brackets to the tank brackets
two L shaped brackets with a hole drilled in one leg of the L that the strap mounts through
the tank straps comprise a flat metal strip with threaded rod welded on each end - the threaded rod passes through the hole in bracket
Morning all - more work done on the fuel tanks yesterday
retaining straps - sliced a 1.5mm wide strip of plastic card then cut that into 28mm lengths
added 4mm lengths of 0.5mm rod for the retaining bolts
the straps were then installed by pushing the bolt ends through the holes in the brackets
I then punched a load of hex bolt heads and drilled through them so that they could be pushed over the strap bolts and glued in place
would have put a thread on the bolt ends but I have misplaced my jewellers tap and die set
Thought you would never get round to the part about the scale threads on this......I guess we'll have to settle for the old slip joint method:tongue-out3::rolling::thinking: Rick H.
Hi Rick - I searched all over but couldn't locate the tap and die plate. No doubt now it is too late it will magically appear again
