SimonT - 4x4 1/24 Esci Range Rover
Simon.
Of course I remember these when they came out, as I said only then real country people owned them, the Police and civil engineers.
Certainly lead the way in those far off days. ( Thank you Steve , no need to remind me :smiling: )
Can't remember any one complaining about them, properly didn't want to admit they were troublesome.
I'm sure you will make a silk purse out of this .
John.
Ian - long term storage hasn't done it any favours
John - if all goes to plan it should be more sows ear in the end :smiling:
Bought a Wilko 10x8" picture frame to use as a base
I shall attempt to make a sort of outbuilding to house the car - breeze block wall with wrinkly tin roof and some supporting steelwork
Only had a few minutes last night but managed to knock together a die for stamping breeze block texture into blue foam
40grit sandpaper glued to a chunk of plastic card with a surround of rod to give mortar
I don't think that looks too shabby
will need care to ensure that the mortar lines align
Morning Simon.
Liking the imprint tool for the breeze block, very neat. To add to that the block pattern and mortar joints look good. Remember most breeze block
construction is built fairly fast and can have quite a rough look to the finish.
John .
Don't worry John - I suspect it will all look rather rough by the time I have finished with it!
Test fitted the chassis tub to the body and found that the rear chassis rails are not long enough
Don't know whether it was just make that way or something has been lost with the warping or what but the rear bumper is so hard against the body that it is causing it to bend
To rectify this I have sliced the bumper off and stuck on some 60thou spacers to the ends of the chassis rails
Should be enough to move the bumper off the bodywork
Simon
Looking forward to seeing this come together as a wreck
cheers
Ross
Simon.
I'm sure you bought things so they would warp with age, another excuse for this drastic surgery.:smiling3::smiling:
John.
Morning Simon
Shame about the warping. Have you tried the hot water treatment yet? That breeze block stamp is a good idea and looks to work well.
Hi Simon, I'll pull up a chair, I'm another former Range Rover Owner. Impressive work on the springs & shocks, looking forward to seeing how this goes together.
Ross - thanks for looking in
John - rats, you figured out my plan :smiling:
Jim - not yet. I have got rid of most of the twist with weight and liberal use of liquid glue. I think I may get away with it just by sticking body to chassis tub. The very hot water that would be needed is likely to adversely affect the thinner parts so I will only use it as a last resort
Graeme - thanks. A 2 door or later version?
Morning all,
some progress to report....
I opened up the wheel slots
and added new wheel nuts and valve
then I balanced the wheels and added rim weights
I course sanded all the tyres to remove most of the tread
then had the bright idea of imparting slight flat spots as tyres do deflate slowly over time
stood the tyres on a baking tray and placed it on the hob, the idea being that I would switch off the heat just as they started to melt
seemed like a plan but I failed to take into account one variable - the level of my own stupidity :sad-face:
breakfast was cooking on the other side of the hob and I switched that off instead of the tyres so they got a little more crispy than I wanted - oops
luckily damage not too bad - I can put the worst ones at the back near the wall
rough and ready wall parts made using my die and a hammer to impart the pattern
mostly ok but a few of the joints will need a little fettling
Unfortunately the process resulted in warped blue foam so I have had to stick them to pvc foam board using No Nails -weighted down with large heavy books overnight so hopefully the warp will be eliminated
it will be a miracle if all this comes together and looks even vaguely like I envisaged
Thanks for looking in
Interesting stuff going on here Mr T. The block work wall looks good....any suspect mortar lines can be hidden behind a traditional garage ‘gentleman’s calendar’ or a ropey looking modular shelf unit :smiling5:
Morning Simon
You never fail to entertain :smiling2: It seems obligatory for your models to go through many ups and downs before emerging at the end as quality results. The tyre idea was a good one - perhaps you should have done it after breakfast. Wall should stay flat with the backing.
Hi Simon, my Range Rover was a four door 89 model with a 200tdi in it, I couldn't afford to run a V8!
I think the tyres look ok considering you are doing it as a rusty barn find, the wheel nuts & valves are a nice touch too.:thumb2:
Steve - cheers
Si - don't think you can have that many shelves or calendars
Jim - plenty of ups and downs for sure
Ross - at least I didn't eat the tyres and stick my egg butty on the car
Graeme - thanks :smiling5: I bet the V8 is a tad thirsty
made a couple of these to support the roof
Nice work Simon so far and sunny side up wheels that's a first for me. :smiling2::smiling2:
Looks great Simon, the dio idea is very nice and love the damage done to the Rover.:thumb2:
Following on from the back seats.
Thanks Fernando
Assembled the frames and main wall section
still need to add the short wall sections but they will need some fettling to make them fit the photo frame base
