That is correct: most Tigers used the same links on both sides but obviously reversed in direction. Initially two types of links were made, one for the left and one for the right, but this was soon dropped in favour of asymmetry, using the original left-hand track for both sides. More info here.There only seems to be one link type and they are asymmetrical which means one track will effectively be on backwards compared to the other side - need to check that out when I find my tiger books
The real question is: will he have to scratchbuild a link for this one too?Even you can't loose one of those track links LOL
How do you go about putting that right ??? New pins or somehow put heads on?the track pins are also incorrect - just straight bits of rod with no head on the end
