Morning all,
this is another one that I have been chipping away at in the background for some time now
I have had a concerted effort to finish cleaning up the track links and they are now ready for assembly
the kit is one of their older ones so not up to their current standards. No etch and rubber band tracks
In no particular order here are a few pictures I have taken along the way
fuel tanks - new filler caps and weld seam from filler
rear smoke drums get etch end plates
barrel is aluminium tubing with a modified kit muzzle break on the end
fuel drum mounting holes filled with bits of sheet plastic
various bits of etch, new bolt heads, lifting eyes drilled open
welds added to engine deck louvres, grab handles replaced with brass wire and heavy duty welding added with filler
side skirts scratched from pewter with punched plastic bolt heads
red paste added for texture
casting numbers added from Slaters plastic lettering
tie down strap is from the Eduard etch set
Masterclub resin links all drilled and sanded
rear track guard from pewter
front end from pewter with etch hinge
