Smallest amount to airbrush
Neil
Neil
Consett
I am just curious, what is the smallest amount people use when airbrushing? In particular I am thinking when you want to paint something small that needs a different primer or colour? Normally, i just go to brush, but my current build will need two missiles in white primer and the rest in grey. That is a small amount to use in a AB as a single colour, or is it?
Depends what mood I am in. I usually go to a brush for the smaller parts.
I use an airbrush whenever I can. Often such a small amount of paint that I unscrew the paint cup. Sadly it takes much, much more time to set up and then clean the airbrush than doing the actual painting.
In truth, that's what puts me off - cleaning for a tiny amount of paint!
I'm much the same as Jim. I only use laquers and they are buggers to brush, so I do as much as possible with a AB.
Waiting to see what the new Gaalhier Omni paints are like. Apparently spray like laquers but no smell and easy to brush, we shall see???
I pretty much air brush everything apart from moulded on detail like cockpit parts or wheel hubs.
Basically anything where masking would take longer than the actual painting/clean up (apart from cockpit canopies etc).
Like Bob I generally only use lacquer paint and don’t really find the cleaning process all that onerous, it’s all just part of the fun 😉
Geoff.
