For model making you do not need the old fashioned soldering technique & solder.
You are far better off with the low heat soldering.
The Dremel as has been mentioned above gives the heat. uses lighter fuel to top up. The picture shows the low heat soldering part on the end.
The low heat solder is just squeezed out in the joint & then heated by the Dremel gun until it fizzes. Very strong joint.
Just been using it on some PE. Holds joints together far better than CA plus. Plus place some solder on the outside of the joint & it fills the joint.
Use a diamond file to smooth then a sander to give a perfectly smooth finish. The low heat is unlikely to distort thin metal but best to test.
Also sticks PE to plastic. But makes a hell of a mess of the plastic. ( do not do please just joking)
