Special Hobby 1/48 EoN Eton TX.1/SG-38 Inbox Review
Dave Ward
I'm suffering from builders' block at the moment, so I thought I'd review one of the more oddball models in the stash
Wingspan 220mm, length 130mm.
Comes in a rather flimsy end opening box...............
Instructions - A5 colour booklet - looks pretty good, but will require careful study!
Decals - mostly for the UK air cadets schemes!
I'll be posting detail shots & comments momentarily!
Some detail shots
This is a short run kit, detail is good, but you do have flash, so careful clean up will be needed
Wings & tail have some nice rib details, may be overdone, but should take a wash nicely.
Quite large ingates means careful removal.
And to the nasty bit!
The difficult part of this will be the rigging - the instructions look clear enough, but aren't for the timid! This is a short run kit, so I have no doubt that a lot of trimming & dry fitting will be needed, so not for the beginner.
Special Hobby also do this in 1/72 - same subjects, but I think you may be a masochist to try & build that!
I got this off ebay for a discount ( enough for p&p ), and is widely available.
If you find this interesting/useful, I might do some more inbox reviews of the more esoteric models in my stash, ones which I haven't seen inbox reviews for.
Thoughts?
Davew
Good luck with that one Dave when you get round to it. Looks extremely fragile!
Nick
Would make an impressive model completed.
Looks interesting Dave and only requires that all align at 90 degrees. The PE should be easily attached and looks like its frame fasteners just like the real thing with bolts already in place.
Interesting subject Dave. Detail looks good, but mould lines are quite prominent on such delicate parts so clean up will be time consuming…will be lovely when it’s built though.
