I have obtained it friends!!
Have the sequence to create the tartan!!
I have throw a small sample in a sheet of plastic.
First primed and then paint a coat of blue. I have put two sizes of type (3mm and 6mm). The major type is for the big squares and the 3mm for the wings of these. I have stuck the big, and then the small one successively in horizontally. Later the same thing superposed in vertical. The squares work out perfect, only it's necessary to cut with a cutter each one. This way I have painted little by little every square.
The result is gratifying!!
Tomorrow I will be able to publish a few photos that show the process (I have to buy a PC for my house ....). Probably it will look like to you a not 'polished" work, but it has been of great help for my, I have discovered many things that I must remember when I
paints on the plane.
The sample is of 3X3 squares, very small!! This one is painted with brush, Without a lot of perfectionism, I have to say... (7 colors in 2cm ... the airbrush is better in the box !!)
The first conclusion is that the primed doesn't support the exit of the type, the fault is also a time of dried correctly. After primed the plane I will paint with a coat of varnish, then the first coat of color and varnish again.
The choice of colors is very important, on having done the sample in brush the colors are seen more intense and slightly homogeneous.
To be very careful with the cutter, not to spoil the sal of the plane or to mark a wound that would separate the union of both paintings.
I must paint one of the type of different color, to facilitate to see where it begins the small one and ends the major one (they go completely together).
The final lines of 1mm I'm not sure how end it, type or a felt-tip pen.
Well, it's better I stop here!!!
Sorry, I'm very deceived, and believe that I can obtain it.
Thanks for all
Polux
