Sprue goo?
BattleshipBob
Bob
Cardiff
One of my 'watch this space experiments' is sprue goo.
Looks easy enough to make but, how long does it last in a bottle, or is it easier to make it in small portions?
Anybody had experience of sprue goo?
Ta bob
I've had some in an old Mr Color paint bottle for a number of years. It thickens up over time as the solvent evaporates but I just add more TET when needed.
If I remember correctly I made half a bottle and it'll probably still be going long after I'm gone.
It does dry out a bit in the bottle, but takes a year or two before you notice it.
One word of CAUTION - if you put it on heavy as a thick paste, then it WILL STAY ACTIVE FOR DECADES.
Just remember ---------------- it is an ACTIVE glue you have made.
In other words, apply sparingly and wait till it dries out COMPLETELY before another coat, like 24 hrs under a 100watt light bulb, so the plastic warms up a bit more than the air temp, to force the active glue to dry.
DO NOT get the light globe too close to the model, or the heat WILL deform the model.
I used it on the top of a sleeper box as I was cutting and shutting the sleeper box, I got sick of waiting to let it dry out completely and foolishly added to thick a coat to the join.
That 35 yrs ago and now the top of the sleeper box has gone ALL SOFT, so BEWARE it will keep working, even though you can not see it happening.
For a filler that is easy to use, then ditch that bottle of glue with sprue and use Super Glue as a filler, just sprinkle Baking Soda over the wet super glue and it instantly hardens to a rock.
Easy to get rid of the extra super glue and baking soda, just use a file, or wet and dry paper to remove the ugly top from the lump of stuff you have created.
LOTS stronger and sticks far better than that goop you just made and it all happens in an instant as well, no long waiting period for it to dry AT ALL.
Many thanks all
Never tried the ca and baking powder trick but will. Didn't release that sprue goo stayed active.
Only if you put it on thick Bob. It's loaded with solvents and thick layers can skin over, leaving the solvents trapped underneath.
Several thin layers work better but it's still not something I use a lot.
Thanks Andy, probably give it a miss.
...Never tried the ca and baking powder trick but will...
It workes great (y) I use it a lot to repair stuff and to fill large holes. It's like the holy grail for inpatient people like myself, instant solid material. Work in layers so the CA can get through all the baking powder. Cheers
Jim, I've found it good in some very specific circumstances, but generally use something else.
Since it (eventually) dries and becomes part of the model, in exactly the same material, it makes rescribing panel lines that bit easier I've found. Fillers and /or CA are often harder or softer than the base plastic and can affect such operations.
Personally I'm using UV putty a lot. You have as much time as you want to shape & smooth it but then it sets in seconds with a suitable light.
It does set quite hard, like CA mixtures, so I have to keep that in mind.
My TET goo has been going for several years now, just top it up occasionally with either sprue or TET and it keeps going. I've found it quite good for going over other filler that has shrunk back.
Many thanks for the many replies and other ideas. Will give the goo a miss. But ill give the CA and baking soda a try certainly
Didn't mention what filler i use at the moment. Creative materials, like the way it can be removed with a damp cotton bud. But always interested in different methods / ideas. Biggest area i use it for is around the prop shafts etc
