started lancy
Fantastic work ole, the cockpit and engines look excellent. This is going to be one nice looking lanc!! cheers tony
Great work on the landing gear. I like a bit of dirt.
Colin M..
the thing with this being only my 3rd real model build the ideas i see from most of the aircraft builders that goes for you to roman,if you pay attention to details it makes for a more pleasurable build,even when i`m in pain i can still paint and then lose a bit more time in the day.So i mean this from the bottom of my heart THANK YOU all of you here for showing me in such a short space of time how much fum this is.
cheers guys Ole Møller aka mobear
Looks great to me Ole, the landing gear is excellent & that's one hell of a big bomb bay!
Keep it coming!
Patrick
Hi Ole your doing a great job on the Lanc Looking forward to more pictures of the build and the finished item
Ole this build is looking awesome,great detailing going on keep it coming!
Ole , dont forget that ailerons were opposite in action, If one was down the other side would be up. cheers tony
yak face its at rest hope its the same both sides when resting
mobear
Even at rest the ailerons would still be opposite to each other , ie. one up the other down , if the glue isnt too set it should be easy enough to move one into the upright position . The elevators however can both be positioned deflected downwards. cheers tony
okie dokie going at it now arghhhhhhhhhhhhhhh
cheers mobear arghhhhhhhhhhhhhhhhhhh
Ole this is looking fantastic! Love the weather effect around the ailerons, what did you use to create that effect?
i use oil paints in differing ammounts of thinner then just before it starts to dry properly i add black oils in creases,and thnx for compliment
mobear
greta work mobear so far... keep it up
i like it a lot
Roman
