Stefees Revell 1/24 '71 Ford Mustang 351 Boss
Stefee
Hemel Hempstead
Stefan
Hemel Hempstead
Firstly many thanks to Geoffers for organising and hosting this GB.
Was torn between this Mustang and a '66 Chevrolet Corvette so if there's any time left might have a crack at 2 builds.
This kit has been widely lauded in the media as being very detailed, very well engineered, easier to assemble than Revells norm and accurate with beautiful Italian sourced decals.
This build will be based on my friend Peter's car. It will be finished in medium metallic green with the silver stripes ( presuming I can match the colour for the painted silver areas. Will not use the seat belt decals and try to make up some and will tint the windows slightly blue as per the 1:1.
Obligatory images to follow.
20260531_120942.webp20260531_121236.webp20260531_121507.webp20260531_122104.webp20260531_122811.webp20260531_122907.webp
An excellent looking kit Stefan, it will look great in metallic green with silver accents. Look forward to seeing the build
OK, made a start with the bodywork as usual.
All parts that will be metallic green or silver removed, minor clean up and mould line removal. Fitted the tailamp panel and rear lower panel into place as the floorpan will go in with them in situ however front lower panel has to be fitted after floorpan.
Front spoiler fitted to panel and rear one assembled, holes drilled and test fitted.
Visible ejector pin marks filled with Tamiya putty.
Thanks for looking.
Big old 70's US Muscle car - goes fast in a straight line, cornering, more of an adventure. But those big V8's sound great.
Yes you are quite right about "grip" when cornering and IIRC the brakes were vastly over- servoed and either on or off. But the noise and straight line acceleration were intoxicating and you became very good friends with the local fuel station staff.
An iconic car for long straight US roads. Looks a nice kit. Off to a fine start.
Never heard of that primer but it looks to have gone on beautifully.
Best primer I've ever used and available in several colours. Because it's a micro filler I always flat down with a Tamiya 3000 sanding sponge.
Proscale are nice paints, I've used several of their manufacturer colours on builds. Mark (the MD) is very helpful and will mix a colour for you even if it's not on the website.
6 coats of Proscale Aston Martin Almond Green applied, now to let it cure and find a match for the silver decals to apply silver paint in appropriate areas then mask and paint stainless steel trim around windows. Apply myriad decals and 2k clearcoat - gonna take a while.
Looking great so far Stefan. A nice sheen on the basecoat showing it went down smoothly 😎
