Steven's Eduard 1/48 F6F-3 Hellcat
Steven000
Steven
Belgium
Thanks Geoff for hosting the 'US Icon's GB',
My project will be this Eduard 1/48 F6F-3 Hellcat in flight :
Sprues - also includes a fuel droptank and bombs,
Decals - Clear parts,
This kit includes 4 color schemes, I'll go with scheme 'B' a shark-mouth from VF-27
Looking forward to this, at the moment also quite occupied with renovation plans
Thanks for watching - Cheers :coffee:
HI STEVEN what the diffenece between the wilcat an the hellcat eh ? becasue to me they look very similar
chris
What the diffenece between the wilcat an the hellcat eh ? becasue to me they look very similar
Hi Chris, the Wildcat was the first design (combat around 1940), it had problems with the new Zero fighters, so Grumman started a new design (combat around 1943) which had almost double the engine power, this became a real Zero killer and dominated the Pacific airwar.
(left) Wildcat - Hellcat (right)
Perfect subject for this GB. These Eduard kits are usually pretty good. Looking forward to seeing this progress.
Thanks guys, made a start on this one...
the cockpit went together well and will get a resin pilot,
A small issue with the engine-front, had to do some scraping inside so the shaft sits horizontal,
I'm doing color-scheme 'B', for this scheme you'll have to remove the bulges on the side of the engine cowling.
This was a bit tricky, started with a file and scraped off the last bit.
For the horizontal stabilizer I believe you'll need to remove this injector pin, it looks like an inside support part but it isn't.
Progress so far, can't wait to start painting something lol
Thanks for watching - have fun - cheers :coffee:
Thanks guys,
Some progress, first added a black primer (vallejo),
Next an olive drab primer (vallejo) and a green interior color (mix),
The pilot and cockpit are painted - I painted the instrument gauges to save some time,
Dry fit with the pilot, his left arm is a bit tricky as it sticks out a little bit, but I think it will still work with the fuselage halves.
Next I need to adjust the tail wheel and glue the fuselage together.
Thanks for reading,
Cheers :coffee:
excellent painting of your pilot, these resin pilots really are good now - where did you get it? I know my mig will be in-flight and Eduard don't do pilots...
