Hope this is the right section as it is stretching it as a paint subject.
In the 8 models so far not had much success with sticking clear plastic. The bond always seems to be fragile. In the latest I have tried Humbrol make a window type, Jewellers glue & the last after total failures by the first two PVA which seems to be the most successful so far. Should add that I have given them overnight to cure. Also I have dried them in a garden incubator which has a temperature of approx 65 to 70 degrees.
Be interested to find how others go about this.
1. What glue do you find most satisfactory ?
2. How do you prepare the edges to be glued ? Do you etch & if so how do you go about it ?
3. Any difference in approach to clear to clear or clear to grey model plastic ?
4. How do you apply the glue ?
Bit of info. Found some non-fogging C/A. But unlike most C/A it takes a time to go off. Tried the special accelerator which is in this group of glues. Sends the glue off but then fogs the glue. Just great. Moaned & they said you need their special unfogged accelerator but found that applying it was so complicated I gave in. Also add that after applying the accelerator to the non fog on a piece of spare canopy it peeled off easily. Amazing the canopy remained un-fogged. Round the houses ?
