Tamiya 1:32 Spitfire Mk IXc
colin m
Staff member
Stafford, UK
This won't be a fully detailed build log, there are many of them all over the web and also far more detailed than I could ever manage.
Anyway, this model is famous and just has no vices. Everything fits where it should, if it doesn't fit, you made a mistake.
My wife commented that the build doesn't seem to be taking too long (I'm on a dead line of December 5th) as I said to her, that's because the endless process of trial fit, modify and repeat, then fill and sand just isn't needed here.
So, where am I up to, pictures.
All of the above is out of the box, apart from a few extra small decals I threw in.
I've started work on the wings, which have about 80 parts in their construction alone. I've built models with fewer parts than that !
Colin M..
That office is coming along beautifully. I am looking forward to starting the first of my three that are in my stash but it wont be until late next year I expect, in the meantime I will enjoy watching your build Colin...
It's a great build of a modern classic kit. Keep up the great work Colin. Any thoughts on what aircraft?
Paul
Beautiful cockpit Colin , the painting and weathering/washing is superb , cheers tony
Thanks all for having a look. So, finally a bit more has been done.
The fuselage halves are attached. All went well even for such a large model. The gun sight reflector isn't in place yet.
The rudder and other moving surfaces are allowed to move using the above pin and PE hinge assembly.
Aileron is attached in the same way.
But do I need movable bits and pieces ? I'm not sure.
I'm starting work on the wing now. There's about 76 parts in all to make the wings, not including guns. I've made full kits with a lower part count !!
Colin M...
Very nice work so far Colin. I've got a big box containing a Tamiya P51-D & I was wondering the same thing about the movable control surfaces.
I guess they're useful to have but not essential?
My ailerons are such a loose fit, I think I'll have to glue them in place anyway to stop them flapping around !
Can I ask did you not need to build an engine before joining the fuselage halves. Great work on the cockpit.
A beautiful model and you are certainly doing it justice Colin
Benhur - no, there is an extensive engine build that will fit to the front of the aircraft. The engineering is superb with the engine panels being ultra thin with magnets so they are removable.
As Barry explained the engine fits onto the front later. The engineering of this Tamiya kit is really something quite amazing.
Well, I've built the wings, as I said earlier, about 76 parts make up the wings.
These little bits are used to create the wheel well.
And then wings completed, including a nice wing spar to keep it all in line. Some say the gun blisters are the wrong shape. For me, it's not important, they're close enough.
Right, I'm of to do a bit of an engine.
Wing assembly now firmly stuck to the fuselage.
Obviously, a nice tight fit.
Also, the lovely engine is complete. No extras at all here, it all came in the box.
This is probably, the most enjoyable part of the build for me. I like engines.
Colin M..
So, the engine is finished, properly this time, including the bits I had sort of forgotten to fit last time. The exhaust is a bit of a pain, six individual pieces (6 each side, 12 in total) to be fitted. But, surprisingly the fit is a little bit loose so alignment is very important.
Primer. This is the Vallejo primer. It's the first time I've used the stuff. I would normally use any 'car type' primer, but thought with a model like this, I would be a bit more delicate and use my airbrush. It worked well straight from the bottle, but did take longer to dry.
Now then, don't be concerned by the poor fit of the panels. The access door is just there to fill a hole and the engine panels are held in place with tape. These panels normally, through the use of tiny magnets, cling onto the engine assembly, which is not present at the moment. But, I need to paint them in place so I get the demarcation lines between the camouflage colours correct.
Any questions etc, fire away.....................
Looks ready to fire up colin!!! They really are the DB's arent they these Tamiya 1/32 , one of these days im going to cave in and get one! Keep it up mate its going to be a beauty. , cheers tony
