This is the first model that I have tried to paint using 1/48th scale paint adjustment. I have often found that the standard colours on my models look dark when used, so here are the colours I have mixed up for this Vietnam canouflage Skyraider.
I just used a mix of Tamiya colours that I had on the shelf.
This is the tan colour mixed for a lightening scale effect.
The scale effect green.
Scale effect Olive Green.
And finally the underside.
For the underside, I airbrushed on a very thin coat of the light grey and let it dry for a few minutes. I then sprayed about 5 thin layers until the desired amount of pre-shading showed through. Once I had dried it in my drier, I went over the paint with a polishing stick to merge in the pre-shading with the grey and smoothed of the matt paint.
The camouflage scheme took a bit of planning! The kit comes with a full model scale plan of the paint scheme, so I placed wide masking tape on the plan and traced the camo. outline with a pencil. Once peeled off, I cut the curves in the masking tape with a modelling knife and stuck them on. Onece the light tan was airbrushed, the mask was peeled off. The camo lines on the fuselage were masked using 4mm automotive flexible masking strip, which sticks well with no residue left and is lovely and bendy
I continued with the olive and then the green, drying the paint and then buffing it down with a polishing stick, to give a more worn and bleached effect.
I finished of with a few coats of acrylic floor gloss (Lakeland brand) to seal it all in. Decals and weathering next, I am aiming to try and keep it reasonably subtle, but I'm not sure yet how it will turn out!
As usual guys, any observations or constructive comments are welcome.
