Thanks Laurie.\ said:Graham tell me more about this please sounds interesting.Like your innovative approach to the camouflage cutting the masking tape. Also interesting as you get a nice cut edge on the tape. For all my work where you need a good clean edge I cut the tape. I have found that the edges on rolls is not so good they obviously use a cutter to cut the rolls off a large roll and the edges are not clean.
The camo lines on the fuselage were masked using 4mm automotive flexible masking strip, which sticks well with no residue left and is lovely and bendy![]()
The 'bendy' masking tape I used for the fuselage cammouflage and the wavy lines between the cammouflage and the underside was finespray 3mm green masking tape.
A very sharp new blade was used to cut the masks for the rest of the cammouflage using the pattern plan included in the kit. I also build up the paint lightly to lessen the chance of paint bleed.
