Tamiya 14137 Yamaha Rd 500 or RZV 500
simontie
New build for first on the new site, image.jpg see how I get on with this older kit the decal sheet is a bit yellow were the white is
image.jpg so i scanned them and reprinted after i found the best setting and these look quite decent so I will use a mix of both image.jpg
Printed on to clear paper as the kit is predominantly white so hoping they work out as i intend 🤞
more as i get started
I'm in for this one Simon. I bought the same kit secondhand a few years back and have yet to build it. My decals are in a similar condition too...
Nick
engine frame & body work still a bit todo but getting there
A nice bike. The real ones went like a rocket, lol.
If you place the decal sheet by a window so they get natural light the UV should de-yellow them.
I will give that ago before i start thanks for the tip
simon
Mid week not spent alot of time over the last week on this but its moving along slowly not the best pics but this is where i am, see how i get on over the next few days have also primed the fairing, used mr hobby white surface & filler primer seemed to go on well but ill see how it is tomorrow when its dry white is a nemesis i never quite get it right but practice as they say …. IMG_3569.jpg
IMG_3568.jpg More as and when thanks for looking
simon
One day I might be brave enough to tackle a motorcycle kit. Coming on nicely Simon.
Sunday night and i have been busy just about completed the bike, working on the fairings and body work & all the other parts are completed
not assembled all the bits as yet but frame engine and rear end all fitted to be fair really went together well only 1 small issue the rear axle seemed short it wouldn't catch and screw in, so i dipped the screw in sprue glue and left it to set, once dry i cut the excess away unscrewed the axle and it worked really well, made a new number plate instead of the generic ones supplied
thanks for looking
simon
IMG_3576.jpg IMG_3581.jpg IMG_3582.jpg IMG_3580.jpg IMG_3593.jpg IMG_3579.jpg IMG_3578.jpg IMG_3586.jpg IMG_3589.jpg IMG_3587.jpg
Well fairings tank front mud guard all painted, might have done this arse for face as i went red then white, hind sight should have been white red but its turned out really well.Click image for larger version  Name:	IMG_3593.jpg Views:	0 Size:	391.7 KB ID:	1240565 Click image for larger version  Name:	IMG_3596.jpg Views:	0 Size:	513.9 KB ID:	1240566 Click image for larger version  Name:	IMG_3597.jpg Views:	0 Size:	503.3 KB ID:	1240567 just the dreaded decals to do next, the rear seat I painted this should be a decal also but a hedged my bets that it wouldn’t sit right!! So i will cut the black pin strip out and use this only…
need to leave it a day or to for the clear coat to harden then ill press on more as i get them
thanks for looking and all your kind comments
simon
Those fairings have come out well Si. Good luck with all the decals.
