I haven't been idle these last few days!! Been in & out of the paint shop, the roof panel and part of the
bonnet came out in an allergic reaction!!! :flushed: :flushed:
Probably something to do with the primer and top coat not being compatible - eventually found it was
the Tamiya Flat Black - which had over sprayed at some point.
Well finally finished the chassis and managed to get the round bits on!
Decided on a finish and gone with something along the lines of Graeme C's BATUS idea, I reversed the colors on the camouflage instructions - replaced the green area with a sand color. Then replaced the
black with the dark green!!
Managed to finish most of the internal bits that need paint on them & glued windows in place.
Fastened the front bonnet to the rear section of body work. This is where I had problems last time.
Tamiya has you fasten the bonnet to the chassis in section 8 - then assemble the rear bodywork and
maneuver this assembled piece into place and fasten the two small pins on each side into the locating holes on the bonnet. But trust me its easier to assemble these two off the chassis - then simply place the completed bodywork over the cab. :thumb2:
Whilst rummaging through the spares box I came across some old etch mesh and decided to "bling" it up a bit!!
(You'll hardly notice it when it's painted!!:flushed
Ready for final assembly:-
View attachment 400706 View attachment 400707
And hey presto - assembled!!
View attachment 400708 View attachment 400710
C & C's welcome, on a £5 please.
Given the top, sides & rear a coat of gloss ready for stickers!!
:smiling2::smiling5:
Paul.
:smiling2:
