Taping
Jukebox64
Can anyone give me information on masking my models?
I have used every type of masking tape I can find including Tamiya masking tape specifically for plastic models and nothing is consistent. Sometimes when I pull off the tape everything is great, other times I pull the tape off and it has left a sticky residue all over everywhere I have masked off.
This means I have to start all over after I send everything back down. Guys I really need help and suggestions.
What paint are you using? I’m wondering if it’s not dry and the solvents are affecting the tape. Tamiya tape is gold standard in my experience. Decorators tape is an absolute no no though, sticks too well, and can weld itself to the surface.
Always use Tamiya tape, but I try to de-tack it before applying to the model by either using my fingers to make it less sticky or stick it to my cutting mat, peel it off then use on the model, works for me !
Always used Tamiya, when in place i rub the edge down with a cotton bud. Then pull off gently close to the start. Never had a problem
Underlying paint must be fully cured otherwise there is a greater risk of damage when the tape is removed. Also the paint needs to have gone onto a clean surface to improve adherence. Preferably a primed surface. I always use Tamiya tape.
I generally use Tamiya tape, but have also recently used liquid mask, (Vallejo) which seemed to work well.
I think good prep is key, eg, make surfaces are really clean before taping.
Is painting with brush, paint away from the tape ends, so paint does not go underneath.
Without knowing what primer and painting materials you are using, my experience is that enamels are the worst culprits for this. You've been making models for a long time with success; is this a recent issue you have experienced?
Enamels especially, need to be fully dry and cured or you risk tape residue or finger print marks in the surface. They are best applied in thin layers and on top of a good primer. The downside is the drying time.
Acrylics can be fragile until they are varnished. De-tacking the tape as noted by others helps prevent damage.
Lacquers are generally bullet proof if fully cured and applied to a clean surface.
For the tape, I use Tamiya primarily, but sometimes other model branded tapes. I have even used household decorating masking tape (definitely make sure you de-tack this, but it's cheap and good for areas not requiring exact demarcation). You can minimise tape use if masking a larger area using post-it stickies, paper, or as I do, the plastic bags which the kit comes in, and therefore minimise the risk to your paint finish.
I’d like to thank everyone for all the advice you guys have given me. I do live in an area in Texas where it does get very humid and sometimes I suppose my paint wasn’t dry enough all the way through. It doesn’t matter what type of pain I use because most of the time by tapping jobs come out just fine but not always so I thought maybe I could get a hint or what I was doing wrong. Now I know I should make sure I paint when it’s warmer outside less humid plus I need to make sure my paint dries at least 24 hours before I try to tape it. I suppose I could detect my tape as well before I put it on. Once more thanks guys.
In humid conditions (not something I suffer with often here in the UK) I would give acrylics two or three days to fully cure before masking. For solvent based paint, like enamels, I would give it even longer.
It might be worth painting a test piece at the same time as the model and making sure the tape works well on that before masking your actual work?
