The Happy Hunter
Andy, looking at your pictures of all the gear in the hull, prompted me to think.....Where does the ballast go? Bearing in mind the high superstructure, presumably it will need quite a fair bit! If so, what sort is used?
There again it will have powerful batteries for all the gear, is that used for ballast?
Thick questions from an R.C. Boat newcomer!
Ron, as far as i can make out it will not want much ballast, those 2 6v batteries weigh a tidy sum alone. There is still a lot more kit to go inside yet as you will see as we progress. If we need any at all it will be at the rear and id probably get down the fishing tackle shop and get some heafty lead weights, i think they call them ledgers. These will be easier to add or subtract as necessary. Before this is done i will need to find the correct water line.
It will be a lesson for us both i think. Stay tuned mate.
Andy
impressive progress Andy, this is very interesting and is giving me the urge to have a go at the airboat i want to make from scratch, the ally, plastic and wood is waiting for me in the shed ... still got a few motors/battery packs and some rc gear so i may have a bash.
keep these updates coming mate, it's a great read.
\ said:
Colin, I've just bought a bumper bag of pop corn, so shift over and dig in! I've ordered the drinks for the next interval....
good job an' all, i've run out and am feelin' peckish. :) :) :)
Thanks Colin. Go for it mate. Give you something to do over Christmas lol.
Andy
Got a couple of 7.2 and an 8.4 (car type) battery packs knocking around if you want em Andy .... or are the battery packs specific to the boat??
Seems that they are the specified ones 2 x 6v never checked the Ah as they were specified for the kit. I know i could fit a 12v 12Ah in that slot quite easily so im not too sure why they have opted for 6v in series. Might find out later, perhaps something in there runs on 6v i dont know for certain.
Andy
Looking good Andy.
Ballast: I belive reading that you hunt...Loose shot is a great ballast. Get all the gubbins in and then find a plastic bag. Put the bag or bags in the hull so that the weight will be even and ballanced. Poor the shot into the bags until the waterline is reached. (dont forget to allow the weight of the super strucktures.)
It helps if you can add some bulkheads to keep the bags free from fowling on things. Once the correct weight and ballance is found you can pour thinned pva into the bags and let it set hard. One set of fitted ballast that can be removed for transport and display.
As alternative is water! you will just need to build water tanks with baffles and you're away. No need to hump round with loads of ballast either...;-) I have a mate that has an RC tug that needs 25kg ballast!! He changed over to water tanks and has never looked back.
Thanks Ian, ill bear both in mind when the time comes.
Thanks
Andy
The dreaded bow thrusters are finished. I took it steady and they came out great i think.
View attachment 54185View attachment 54186View attachment 54187View attachment 54188
The next thing i wanted to do was to make sure the whole thing was watertight, i decided to go a little OTT on this part. Best to be sure.
Here you can see that i have added the oil filler tubes for the prop shaft lube and waterproofing.
Next part was to start the aft deck. This has quite a few parts to it and it has to be built upside down. Making sure that it isnt built the wrong way round as you will see there is a lip on the right top side when the right way up.
View attachment 54191View attachment 54192View attachment 54193View attachment 54194
Andy
Looking good Andy, i see your giving her all the bells and whistles and i saw a video on youtube of her with all the things working and it looked great
cheers steve
Cheers Steve. I saw that video to. There is a lot to go inside this thing, should make for a good build i think.
Andy
Continuing on from last nights episode, the next job is to make the covers fit into the slots. Only slightly oversized didnt make it too much of a job.
View attachment 54227View attachment 54228View attachment 54229View attachment 54230View attachment 54231View attachment 54232
Once in place its time to turn over and glue in place the strengtheners, these have a slight curve to follow the deck curve for the water to run off.
View attachment 54233View attachment 54234View attachment 54235
Now complete its onto fixing the deck rail that the aft deck will sit on and be glued to.
View attachment 54236View attachment 54237View attachment 54238
Next is to fit the deck, some sanding was necessary to get it to fit snug. Now we can see the extra 3mm lip that was to be left on the stern. Once the deck is glued into place this lip can be sanded level with the deck.
View attachment 54239View attachment 54240View attachment 54241
Starting to look a little ship shape now haha.
Andy
Looking great Andy!! Very clean Job!!
I love your your atmosphere and the touch of tranquility in your models!
Polux
Looking great Andy,for us non boat folks whats a rollor box?
You know Trey im not quite sure myself. Id be guessing but i think its to do with the towing rope and that it would have rollers on it for the rope to run over when the winch is working. Perhaps it will become clearer to us both as the build goes on and more bits are added to it. There are some other parts to stick on it yet i think.
Andy
me too, ive no idea what a rollerbox is but it looks mighty fine anyway andy! top work mate , keep the pics coming , cheers tony
You hit the nail on the head Andy. Its a box or frame that holds the rollers that protect the tow cable and the stern of the tug.
nice work on the deck so far, looks like its going together quite well.
Thanks guys for the kind words and thanks Ian also for confirming the Roller Box. Here are some more for you, Scuppers and Hawses. Learning all the time with this one.
Well first off i needed to fit the Bulwark would you believe lol. its the part that runs around the stearn above deck level.
And now for the Scuppers and Hawses.
View attachment 54341View attachment 54342
This next part was a real nail biter i can tell you. As you can see from the inside of the Scupper there are slots that have to be cut out for the water to drain off the deck, OMG what a risky job, you cant do it from the deck side because you cant get the Dremel in to do it so you have to cut blind from the outside. I decided to shine a tourch from the inside to give me some guidance as the light shone through the single skin that needed cutting out. The tricky bit is to cut it out with the Dremel without going outside of the said area, the real tricky bit is not to cut too low as the Dremel would eat away the deck and that would be a disaster. The cuts in the Bulwark had to be done with no guide as there was nothing on the inside to guide me, a total guess work job on these 2. Anyway, as you can see below i got away with it this time, fingers crosses for the upper deck.
View attachment 54343View attachment 54344View attachment 54345View attachment 54346View attachment 54347View attachment 54348
Andy
