\ said:
Didn't get the results i was hoping with the new Klear, so i raided HWMBO's cleaning stuff.:bangin:Found this stuff and gave it a go.only try'd it on the quadford's glass and a 1/48 spit canopy the results once dryed is amazing. try it for your self. CheersMartin
I can't see how that would work the same as Klear, Klear is an acrylic varnish for hard wood floors, this is a fabric shampoo, most likely it worked on the canopy by cleaning it rather than coating it which is what Klear does, it's thin enough to flow into tiny scratches etc and give the appearance of the canopy being thinner.
Regarding a replacement for Klear, this stuff.
http://www.longrangelogistics.com/wp-content/uploads/2010/03/uk_pledge_multisurfacewax-213x300.jpg
Which is the rebranded Klear behaves exactly the same as the old stuff though it's translucent milky white rather than see through and clear.
The only other downside is the new perfurmed smell, it digs into my head a bit as well but then i've never been able to stomach the perfume sections in dept stores either.
It's available in Morrissons supermarkets for £3.50 ish a bottle
As an alternative, I also have Xtracrylics varnish, cheap, excellent, thins with water and sprays well.
