this is coming on well Kresten
scott
scott
Do a full strip down clean. Dont forget the needle guard! Also check the needle. Carefully take it out and draw it backwards and twist it at the same time on the back of your hand or inside forarm: somewhere where the skin is soft and sensitive. It might be that you can feel a slight scratch which would indicate that the end of the needle has gotten a knock. If there is a bur or rough bit its not the end of the world. First try just cleaning it in some thing like cellulose thinner. some thing that will thin/remove all paints, no matter how hardened they are. I use Xylol which can remove six week old acrylic from my desk like it was never there!!!\ said:Thanks Ian.I would normally freehand the camo but my airbrush has been acting weird, not sure what im doing wrong. It is spraying what seems like dried paint arounf the outside of where im painting so i dont get a nice even line, more of a splatter. It is really getting annoying. lol. I would need a rather large yard for a 1:1 scale drawing. LOL.
Kresten
Yes, the stuff I bought was fairly concentrated. It's called "Kleen Off" and goes under the Jeyes brand. I was many,many years ago trained as a chemist but I can't find any indication of it's actual strength. For any fellow chemists I was looking for some kind of molar concentration. I just took a whiff,decided it was pretty strong and diluted it very roughly 15-20/1 with water. You can still just about smell ammonia but it's not like smelling salts and it still removes Klear.\ said:dilute with 15 parts water Steve?
