Morning all,
After some advice or some technical knowledge from the good folk in here.
Currently I'm using VMS gloss varnish and the guidance says 2hrs before a second coat!!
1. Do you empty and clean the airbrush between coats? Being Varnish I have no doubt it will cause some clogging in the airbrush?
2. Is there a way of speeding up the process ? Hairdryer eg?- Will this spoil the finish?
3. Any other varnish out there that does not take so long to dry between coats?
4. What needle size do you tend to use while varnishing? I usually do 1:72 through to 1:35 scale kits
Thanks
Meirion
Thanks
Meirion
