WW2 SAS soldier with machine gun 1/10 bust
yak face
Staff member
Tony
Sheffield
Here we go with another first for me , a large scale bust. I got this cheap on the net , since finding out its a Young miniatures sculpt . Its very nicely done although I’m going to delete the monkey on his shoulder and the eighties style Ray bans on his head will have to be altered to be more suitable for the ww2 era. Ive got no instructions so the assembly of the .50 cal MG will require a bit of research , plus ive got the barrel to straighten out ( any tips welcome , I’m thinking very hot water? )
Figures still scare me to death but hey ho , off we go ! IMG_8533.webpIMG_8535.webpAnd heres a pic off the net of what it should look like IMG_8534.webp
An interesting figure, you should get lots of fun out of this one Tony.
The Rayban sun glasses would be period correct, surprisingly.
Looks a very well detailed sculpt. Luckily it looks like the monkey is a totally separate moulding. The detail on the shirt shoulder is unaffected.
Thanks joe , yes I did a bit of research and saw that they could be correct . I’m actually relieved as trying to alter the shape or removing them altogether would have been very difficult and in this scale it has to be spot on . I also read that sunglasses were frowned on in certain cases - the suns reflection off the lenses could give away the position of a covert unit . Anyways theyre staying and the monkey isnt .
Yes jim luckily the monkey is separate , just a square hole to fill and his tail to sand off , which I did yesterday and its come out ok IMG_8539.webpIMG_8542.webpIMG_8543.webp
So , anyone want a 1/10 scale monkey eating a sandwich ?
Had heard hot water to straighten that barrel Tony.
Certainly NOT heat, in my case an important reason!;)
Cheers john , yes I seem to remember people heating resin up with boiling water to make it a bit more pliable , definitely not a naked flame , I think its quite flammable stuff .
If this fails I’ll have to say its a top secret SAS weapon for shooting round corners 😆
Interesting sculpt..... I would have thought sand goggles would have been better than raybans..... But still going to look good..... Best of luck with the 50 cal
I've just been googling to see if I could find a pic that maybe this sculpt had been based on..... Didn't find one but there is one of Paddy Mayne in sunglasses, but not rayban aviator style, so it is plausible
Cheers paul , Yes I thought sand goggles would be more likely but I suppose a SAS soldier getting hold of a pair of Ray bans is more plausible than having a pet , sandwich eating monkey!
Well the hot water trick worked fine - the bent gun barrel and the deformed top of the machine gun body were straightened out after sitting in a jug of hot water straight out of the kettle . I managed to find some good reference for what the gun looks like and added a few details that were either missing or not very well formed. The bullets have quite a bit of flash ( if that's what you call it on a resin moulding ?) so will need some careful cleaning up . Ive attached the right arm and hand and the three main pieces will be primed and painted before assembling last off . IMG_8552.webpIMG_8553.webpIMG_8554.webpIMG_8555.webpIMG_8556.webp
Glad the barrel straightened ok. I like the additions/improvements.
Cheers jim , not sure about the bullets yet though , theyre so fragile I dont think they can be cleaned up without breaking into pieces. Anyways the main bits have been primed now - grey for the gun and white for the figure IMG_8557.webpIMG_8558.webp
Hot but NOT boiling water mate! Ask me how I know ...
A little progress has been made on this . The gun has had a base coat of gun metal and will be getting a gloss black wash to darken it up a bit. The various parts of the figure have had some colour applied , only a base at this stage , various highlights /shading will be added later once I get the wet palette out . IMG_8575.webpIMG_8576.webp
After a bit of a hiatus i’ve got some more done on this . I got the wet palette out and started on the head . After a base of flesh its had various shades and highlights and hes had his beard, eyebrows and eyes painted . I’m happy enough with how it is now and am resisting the temptation to keep messing , which usually results in cocking it up and having to start again. The torso and arm have also been shaded/ highlighted , the shirt possibly needing a little more highlights adding . The problem of the dodgy bullets has been beautifully sorted thanks to a very kind offer to 3D print some for me by @Neil Merryweather . The new ones are superbly detailed , just needing a little bending to shape . IMG_8791.webpIMG_8792.webpIMG_8793.webpIMG_8794.webp
