Yaks muscle car build - revell 1/25 Camaro z28
Interesting, so what will you use for thinners ? cellulose ?
Yes , ive got a single action external mix airbrush , you know the cheap suction type with the conical brass nozzle that just pokes up into the airstream . Ive been experimenting with this and it seems to work fine, the advantage of this type is that there are no seals to be affected by the cellulose , and no moving parts that are in contact with the paint so its easy to clean and less prone to blockages/ drying .ive even had a go spraying some with quite large flakes of glitter in them with reasonable results.
I started the paint job today , i wanted to do this first so the paint has plenty of time to harden while i build the rest before polishing. First the shell was de-seamed and primed with white primer (this was actually done about a week ago), this was then rubbed smooth with a very fine sanding sponge ready for the top coat. The nail polish would have no trouble sticking to the bare plastic but as im thinning with cellulose I wanted the extra protection of a primer coat to avoid any reaction with the plastic. I thinned the nail polish 1/1 with cellulose thinners and sprayed it on in several coats not leaving too long between (about 5 mins) It has to be sprayed fairly wet or it can dry quickly and get the orange peel effect. The final coat was about 3/1 thinners to polish misted on to flash the surface and give a smooth finish. Its not super glossy yet , im going to polish the paint when its thoroughly hardened. heres a few pics to show what i did
very nice Ian,do like the color,;)
I have that type of AB,is that a fine or bigger needle ?
and aalso I did damage the needle in some how,no clue what I did,:confused:
but need to get a replacement one from some were,for it,:rolleyes:
Its just the standard one Monica , its not a neede as such ,just a pin and a screw up or down nozzle, theyre only about £8 over here , not sure what that would be in AUS dollars but im sure you could get one off ebay cheap , cheers tony
ta Tony,for the whole set hear is about $22.00,that's the part I cocked up the screw up needle thing,:confused:
Ok heres where im at now. The body has had plenty of time to cure so its time to polish it up. For this im using Eucryl toothpowder , a very mild abrasive applied with a damp cotton cloth and finger. The beauty of using this is that unlike some petroleum based car polishes theres no chance it will react with the plastic or paint. Its only £1 at Poundland (surprise! ) and it will polish the paintwork nicely. heres the pics of the process, the bonnet has had the right side polished and the left unpolished to show the difference , the triangular shape is a test piece that I sprayed at the same time to experiment with the polish first. next steps the engine ,chassis and interior, cheers tony
Looking very nice in that blue Tony, and another advantage of using the toothpowder is the nice minty smell. :)
Interesting use of nail polish - first time I've actually seen someone show their application.:cool::cool::cool::cool:
Well the decal stripes have gone on beautifully , typical modern Revell decals . Ive just got the air vents to paint black and the window surrounds and wipers /door handles etc. to paint then the body is ready , its just a case of sorting the engine and interior, cheers tonyView attachment 275914 View attachment 275915 View attachment 275916
Looking good Tony, loving the colour mate. And loving the Eucryl too, would never thought of that one.
Have fun, John
Looks rather good that. I have some freaky colour nail varnish I bought for a beetle but could not get it to go down. I will follow your lead and have another go one day.
Now that body looks sweet truly a delight to see and the polishing you have done really brings out the true colour ( like a good wax on the real thing)
Does the polish have to be sealed afterwards or is it like a final polish coat ( if you know what I mean.
Lobe the colour really do
Robert
Cheers robert , i just polished the paint then applied the decals , im going to try a water based car wax for the final shine but im going to try it on the test piece first, cheers tony
The reason I ask on the polish is I'm aware that most Jets would nave a Matt finish but when the early jets came out it seems they had a somewhat shine and gleen to them and I'm wondering once painted I could polish it up?
Advice always welcome
Regards
Robert
Regards
Robert
If its for the phantom robert i would try a satin varnish , i think a full blown gloss would maybe be a bit too much in this scale. The trouble with polishing is that if theres not much thickness of paint then theres the danger of going through , on the camaro i gave it about five coats of nail polish ! Cheers tony
