Latest Acquisitions (2023)
  • Lee W
    • Feb 2014
    • 4704
    • Lee
    • Sherborne
    #1021
    What on earth is it ?
    Brush cleaner John, nice and cheap... it'll probably fit nicely in the bin after a couple of uses!
      Wow thanks Lee, so not a recommended buy then
      • Richard48
        • 2245
        • Richard
        • Clacton on Sea
        #1023
        On looking for a little off-the-beam model - postie just delivered this
        [ATTACH=CONFIG]n1202960[/ATTACH]
        From Ebay - but not an auction - a ' buy in now ' at £12.43, free postage!! Ordered yesterday, delivered today - if you're interested they still have 7 in stock - also check out the HB Komsomolets at £11.69 ( 10 available ) - not one I'm interested in.
        Makes all that browsing worthwhile occasionally!
        Saw this weird little tank on e.bay Dave.Low price as well.
        • Waspie
          • Mar 2023
          • 3488
          #1024
          Fuerteventura...
          Can you take a little more off the sides and back please...
          I take it the convict look is back in!!!
            Tnat's already on my watch list!
            • Lee W
              • Feb 2014
              • 4704
              • Lee
              • Sherborne
              #1026
              I'll let you know mate :thumb2:
              For me it never went out! :tears-of-joy:
              • adt70hk
                • Sep 2019
                • 10552
                #1027
                Good evening all
                Firstly sincerest apologies for not being around much this week. Just couldn't find the time somehow.
                So the follow have turned up in the past couple of weeks......
                The tow cables are for my current and some other long stalled builds. I actually managed to get these half price (incl. p&p) because of a load of loyalty points I have with the vendor. The odd thing is that both the StuG and Pz IV versions come with an odd number of eyes for no obvious reason....3 in one case and 5 in the other but only three cables between them rather than four....and that's how they come, they're not faulty sets....
                This Eduard forced itself into my eBay basket.....it's from a retailer I have used on a number of occasions and for some unknown reason he is currently selling new kits at ridiculous prices.....cheapest 'normal' price for this is £29 delivered.....this cost me just over £17.....delivered....40% cheaper. It would of course have been rude not to!
                I'm still not sure why I bought the below AB as I already have two perfectly good - if not deluxe - ABs but I think I have got a good deal.
                These are a new company (apparently Chinese made) but only available on Amazon's US site. I first saw them on a UK YouTube channel called Gary's Stuff (HERE) but the US' Barbatos Rex also reviewed them (HERE)....and they both raved about them.
                Initial thoughts are very good:
                • Very nicely packaged although it got a bit creased when it was forced through the letter box ;
                • Nice set of instructions, including a full parts list in diagram form;
                • Each AB is tested before it leaves the factory and they include the test card (gimmicky??);
                • 0.35mm and 0.5mm needles/nozzles;
                • Seals are PTFE, not rubber;
                • Two different size screw in paint cups (1/4 and 1/2 fl. Oz [7mm and 14mm)], both with lids;
                • Whilst these cups are very large, the AB can be used without them if you have a small amount of paint due to its design; you can just drop it into the hole;
                • Apparently the needle is made of 'spring/springy' steel that makes it less prone to being damaged (see c. 6:30 on Barbatos Rex video).....will have to see how that works;
                • They do seem to be very nicely built and not at all cheap;
                • They come with a quick release attachment, lube and spare seals;
                • but what really got my attention was that it has one of those compression fit, self-centering nozzles that you don't have to screw in and risk stripping the thread on - just like the Iwata Eclipse SBS, albeit a different shape.
                The Gary's Stuff channel has arranged a 20% discount via Amazon, which wiped out the tax I had to pay and so even with the $9 delivery it only cost me £45.
                If it's as good as they say, then I can see this making a really good entry level AB for the novice....but I still can't quite work out why I bought it....
                I might do a mini review after I've used it a bit.
                ATB
                • Mini Me
                  • Jun 2018
                  • 10711
                  #1028
                  I took the Corvette and SWMBO on a little road trip to Missoula, MT. today, about 180 miles round trip. Went to the only Hobby Shop within decent driving distance for some supplies I was running low on. while there I found a couple of old Preiser kits: fuel drums and Machine tools.........future dio stuff.Click image for larger version
                    • 19130
                    Originally posted by adt70hk
                    Good evening all
                    • They do seem to be very nicely built and not at all cheap.
                    ATB
                    Airbrush looks to be a well thought out tool Andrew. The test sheet isn’t a gimmick either, I’ve seen that before on high end railway modelling kit. My drop riveter came with a strip of test rivets and my lining pen came with a set of lines to show what it could do.
                      Retired two Bosch, one small, and one large, about four years ago, mostly because the chargers regularly died on them. Got a good deal on a Dewalt with two batteries from Screwfix and it’s absolutely amazing. Drills through anything, and is about half the weight and size. Last ages on one charge as well. Moral I’d, save up a bit more and buy Dewalt, it’s simply superb in comparison.
                      My neighbour is a bespoke chippy, he fits all those drool over kitchens you see advertised for the hoy palloy - just ask the wife - she will know what I am on about. So running his own business he gets discounts and is doing me a favour and ordering a couple of Makita, one for heavy work and one for general, after all he gets the tax back on them...
                        Originally posted by Andy T
                        If I keep going like this I'm in danger of building up a stash rather than my usual buy one, build it, buy another :smiling5:
                        [ATTACH=CONFIG]n1203077[/ATTACH]
                        Another of the mid sized tamiya kits as I find them just right for a quick, relaxed build.
                        A big bottle to replace the best acrylic varnish I've tried yet, and something to hopefully assist with my panel line handicap.
                        Despite trying every medium I can think of I'm still never happy with my efforts so will give this snake oil a go.
                        Brush rinsing doodad. Dispenses clean water each time.
                        Probably better than my sludge filled jam jar.
                        Notice you are building up a stash of 'Paneliner' - this is how it starts, believe us - paneliner today - clothes out and wardrobe full of kits tomorrow....
                          Originally posted by Mini Me
                          I took the Corvette and SWMBO on a little road trip to Missoula, MT. today, about 180 miles round trip. Went to the only Hobby Shop within decent driving distance for some supplies I was running low on. while there I found a couple of old Preiser kits: fuel drums and Machine tools.........future dio stuff.[ATTACH=CONFIG]n1203090[/ATTACH]
                          See Andy!!! this is how it starts, the pull is so strong mileage means nothing to the true stasher... Had to leave the wife at the store to get the goods home....
                          • adt70hk
                            • Sep 2019
                            • 10552
                            #1033
                            Thanks Tim.
                            I clearly fell for the sucker punch advertising but it does look very good and feels as solid and well put together as my other two AB's.
                            The nozzle is different to yours but the thought of not having to find a wrench each time and risk losing the nozzle, or damaging it every time I take it off was appealing. Apparently the needle is made of a 'spring/springy' steel that makes it less prone to being damaged......will have to see how that works.... :thinking:
                            Even if it proves to be a bit worse than my other two, I will use it as a dedicated primer AB and keep my other two for the finer paint work.
                            ATB
                              Yep! for Yobs n slobs.....
                                Having built a fair number of M4 and a few M3 medium tanks in recent years, I also kind of wanted an M2 for the line-up.
                                [ATTACH]484093[/ATTACH]
                                You’ve got three choices for that, as far as I can tell: Commander’s Models in traditionally cast resin, Vargas Models in 3D-printed resin, or scratchbuilding. As I didn’t feel like that last one, I figured that if I have to have an expensive kit shipped halfway around the world, I might as well go for the middle option.
                                Here are the main parts you get:
                                [ATTACH]484094[/ATTACH]
                                What I do find slightly weird is that this took two weeks to reach me from the USA (the label says it was mailed on 3 June, it arrived just now on the 17th). Yet I’m still waiting for an order of two figures from a UK-based manufacturer, which I purchased in early April …
