With little or no time for a new diorama, I have decided to rehash an old diorama which has never been entered in the Penang MALCOM competition. Some of you may have seen it before when I posted some finished dioramas in the past.
There's quite a lot to spruce up all-round including the figures and tanks. Ground work needs muddying a little or churned by the tracks. Decals are peeling and need to be redone.
The other option is to continue with the Church archway Dio which also has quite a bit to do as well...
As for the Hurtgen forest I have started on preparing more trees and debarked some hedge stems from the garden...
I'm picking the straighter ones and probably adding three to four more trees.
Wabble
There's quite a lot to spruce up all-round including the figures and tanks. Ground work needs muddying a little or churned by the tracks. Decals are peeling and need to be redone.The other option is to continue with the Church archway Dio which also has quite a bit to do as well...
I'm picking the straighter ones and probably adding three to four more trees.Cheers,
Wabble
