Here's a nice varnished Scale75 base for a bust I'm painting.
I need to drill a hole for a 4mm rod to support the bust, and if it isn't perfectly centred and vertical, it'll look horrible.
I don't have a pillar drill (the obvious solution) so I'm looking for an alternative method. Centring the hole shouldn't be an issue, and I guess I could just eyeball it to get it vertical, but it only has to be a little bit out to look really naff.
Probably the 'right' answer is to use a pillar drill! I have got a Dremel, so perhaps their pillar stand is worth getting. Any other ideas?
I need to drill a hole for a 4mm rod to support the bust, and if it isn't perfectly centred and vertical, it'll look horrible.I don't have a pillar drill (the obvious solution) so I'm looking for an alternative method. Centring the hole shouldn't be an issue, and I guess I could just eyeball it to get it vertical, but it only has to be a little bit out to look really naff.
