Thanks for that Steve, I have considered some clear plastic, I has some spare bits that may be suitable, how would you apply the heat, eg: hairdryer or similar? or place in very hot water? As I'm assuming a paint stripping heat gun or blowtorch or even a candle will be too much and just melt it! CheersOne thing you could do Peter if its a bit thick is use a thin piece of clear plastic, something from a drinks bottle, and cut it and shape it with some gentle heat and use that for the back section then your center section will fit over it.
Depending on the plastic. You could try a hairdryer. If that doesnt work I would get a piece of smooth bar with the correct curve on it. Heat it up and then just hold and shape the plastic by pushing it onto the heated bar. You may to try various degrees of heat before you get the right one.Thanks for that Steve, I have considered some clear plastic, I has some spare bits that may be suitable, how would you apply the heat, eg: hairdryer or similar? or place in very hot water? As I'm assuming a paint stripping heat gun or blowtorch or even a candle will be too much and just melt it! Cheers
Yeah, I think I might just get away with it, we'll see....Looking good Peter. As for the canopy, if it looks at 2 foot, that would do me.
